Old 01-13-2008, 09:50 PM   #16
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
ahh the never ending 'to do lists'
on the e36:
-busted pass side wiper sprayer nozzle
-reclamp washer fluid hoses- leaking= no worky
-pass side window dead
-drvrs side window goes in & out -short
-srs light is on - cel goes on & off too -needs scanning
-slight occassional steering wobble (ball joint or cntrl arm bushn)
^ no point cause the potholes are death this year! ^
-rust (minor) on the rear fender archs (both)
-bottom of pass fender pushed in a bit
-install m3 front control arm bushs
-install uuc street tranny mounts
-swap in LSd (probably will need new rear bushs)
-need parking brake (complete+ cable)
-need windshield: cracked below wipers
-need pass fender liner re-installed
-need brake ducts re-installed
-need new fog lights
-refurb & p-coat the style 5's
this winter so far i've had the Heat fixed & New Brakes installed..
then i got that Rust hole around my driver side wiper fixed!
Old 01-14-2008, 10:15 AM   #17
chromius
chromius's Avatar
Tell me about it! They're like craters. I constantly look as though I'm drunk because I'm swerving around them like a madman.
Old 01-14-2008, 12:20 PM   #18
ecuconnection
ecuconnection's Avatar
time to switch to concrete roads... maybe???
Old 01-14-2008, 01:30 PM   #19
Nascar318is
Nascar318is's Avatar
Originally Posted by Jamil20 View Post
Also need some new side molding clips,
I have some clips in my bimmer under 10 feet of snow As for me, I need a ummm thing for the front that has a balljoint in it.. and a wheel alignment. Other then that, I reaaallly need a full body job, but I want a house.. so no cash...
Old 01-14-2008, 01:31 PM   #20
Philboski
Philboski's Avatar
I'll join in here:
-Find my intake leak and fix it (yeah, with my luck, that means I am doing the CCV and the intake manifold gasket. Toss in the valley pan for good measure)
-find the cause of my airbag light and fix it (apparently it's some module or some such under the drivers' seat)
-find and fix that juddery vibration I am getting from my exhaust
-hood release cables
-drivers' seat cushion
-rust on inside of drivers' door (hello, POR-15)
-if I get to it, the right rear regulator
-a solid buffing
-a serious interior cleaning
-deal with my regret for not buying Bilsteins.
Philboski is offline   Reply With Quote
Old 01-14-2008, 02:03 PM   #21
Jamil20
What'd you buy instead of Bilsteins?
Koni? I've heard good things about Konis.
Jamil20 is offline   Reply With Quote
Old 01-14-2008, 03:52 PM   #22
Philboski
Philboski's Avatar
I went with stock, which are by no means a bad choice, but I was hoping that they would be a smidge stiffer than they are.
The BavAuto guys dissuaded me because the Bilsteins (HDs) can raise the nose of the car a smidge if you have the sport package.
Old 01-15-2008, 12:22 AM   #23
oldskool3
oldskool3's Avatar
ahhh the To Do list
Here's the e30 version
-change oil/ filter
-reinstall stock flow matched injectors
-reinstall stock air box with K/N
-adjust valves
-find new 3.73 LSD diff and instal to replace whining 3.73 currently installed
-check for vacum leaks with propane (new trick I discovered on r3v)
-sand down and paint rockers with 3M rock gaurd
-remove and paint bumper surronds
-remove bumper and replace non functioning driver side turn signal
-remove and paint rear spoiler
-remove and paint front spoiler
-reinstall deck that PO shitily installed
-install new day time running lights in euro elipses
-install osrams sitting in my room in euro elipses
-buy new BFG's/ spacers and install enkei mesh that were stolen from Lee (ssshhh)
--buy from Adam and install new IE urethane rear subframe bushings
-wash/ clay bar/ wax e30 and pray paint comes out halfway decent
-replace cracked dash with non-cracked dash in storage
-install racing dynamics rear strut bar sitting in garage
-steam clean carpet
-remove carpet and por 15 floor
-leatherique seats and pray they turn out halfway decent
Future to do list
-find/ buy/ paint/ install new sunroof to replace rusted one
-find/ buy/ paint/ install new fenders to replace rusted ones
-save money for new suspension parts/ m30 parts
-realize I don't have any money for any of these things and conitnue to drive indestructable golf.
I know I am missing a huge list of projects. Eventually I will buy colour matched euro bumps and an alpina replica front spoiler. I also need to have the front subrame welded/ replace for non cracked one and I want an e36 rack but those will probably happen with the m30 swap b/c it will be 2000X easier. Plus I need to run a new hard line from rear brake T junction to the m/c because I don't really trust that crush washer.
Old 01-15-2008, 09:22 AM   #24
Philboski
Philboski's Avatar
How does one check for vacuum leaks with propane? I have this vision of rooting around under the hood with a barbecue tank.....
Old 01-15-2008, 12:35 PM   #25
carjoe
carjoe's Avatar
Gee, I'm not sure if my car needs anything. I might pony up and get the A/C fixed this summer. Otherwise it's been doing well in storage....I started it up over the weekend. Started right away too.
Oh, I think I need a tie rod on the left side but that might be it.
93 325is - sold!
2000 540ia- sold!
Old 01-16-2008, 02:32 PM   #26
Using a small propane torch (the kind you'd solder copper pipe with) you crack the propane but don't ignite it. If the propane gets near a source of vacuum leak, the propane gets pulled into the intake and burned, which caused the revs to bump up.
There is the possibility of blowing yourself up.
Old 01-16-2008, 02:37 PM   #27
Striker
Turbo Ready
Striker's Avatar
After nearly 2 years waiting, working on everyone else's car, mine is finally next in line
Thinking of this engine as a possible swap
My list is here http://bmw.turboready.com/phpbb2/viewtopic.php?t=287
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 01-16-2008, 02:38 PM   #28
Nascar318is
Film this if you do it! Set the camera on the tri-pod a couple of 100 feet away and zoom in on it, that way the camera won't melt incase you die.
Old 01-16-2008, 02:52 PM   #29
chromius
chromius's Avatar
I love this disclaimer
Old 01-16-2008, 04:17 PM   #30
ecuconnection
On the menu tonight.. a hot dog and ribs with a side of e36
