Old 01-02-2008, 10:37 PM   #1
topnotchraly
topnotchraly's Avatar
Need e-test advice E36 318i
My 97 318i with 250k kms failed the etest. I half expected this because it barely passed two years ago. I was a bit foolish in that I took it for the test without doing anything. I did replace the air filter before the test.
I have since replaced the spark plugs with new Bosch OEM ones, the old one were pretty shot, though the car ran fine, had been in for 75k kms.
The cat. was replaced 5 years ago, nothing else has been changed. The Check Engine light comes on every 2-3 months saying the cat is failing but I just reset it and it each time.
Anything else I should do before trying the test again? (as I said, I have changed the plugs)
Change the oil?
What gas is best to use? (I normally use 91-93 octane)
Thanks,
James
topnotchraly is offline   Reply With Quote
Old 01-02-2008, 11:23 PM   #2
archrival
E36 Addict
archrival's Avatar
What did it fail on? Idle or driving and on what gasses and by how much? Also what kind of cat was put on when it was replaced last?
archrival is offline   Reply With Quote
Old 01-03-2008, 12:16 AM   #3
e30_kid89
The Afro-stig
e30_kid89's Avatar
You should be fine with a OE cat or decent replacement. Try a oil change, and o2 sensor. Drive on the highway to the test center in like 4th to keep the rpm's high and the cats hot so when you roll right into the test center its hot and can do its job even more effectively.
Old 01-03-2008, 10:04 AM   #4
topnotchraly
Good point, I should have mentioned that. It passed the idle test fine. It failed all three gases on the load test.
150% over on the HC
12% over on CO
100% over on NO
To answer the other question about the cat. Don't know but the whole cat pipe was replaced from the down pipe to the rear exhaust pipe (it's one piece) I assume it was an OEM quality part.
Thanks,
James
Old 01-03-2008, 10:07 AM   #5
topnotchraly
I also just noticed that the 'dilution' on the load test is 15.1, but it's 14.2 on the idle. Does that mean it's lean?
Old 01-03-2008, 04:45 PM   #6
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
02 sensors arent that expensive.... and if is never been done at 250K its time.
electric contact cleaner the maf sensor & clean your throttlebody flap.
Old 01-03-2008, 05:02 PM   #7
rwdbmwm3
yeah id say O2 sensors... if you want 100% answer, get your car scanned by someone who knows what they are doing (im not talking about the garbage scanners but an actual couple grand scanner)
rwdbmwm3 is offline   Reply With Quote
Old 01-03-2008, 05:40 PM   #8
Mickey Knox
vacuum leaks
check for vacuum leaks too
Mickey Knox is offline   Reply With Quote
Old 01-03-2008, 08:21 PM   #9
BalloonWhite
PVC valves are also a big part of why cars fail e-missions test
BalloonWhite is offline   Reply With Quote
Old 01-07-2008, 10:42 PM   #10
archrival
E36 Addict
archrival's Avatar
ok so judging by what you have i would say an O2 would be a good thing to replace. toss a bit of methyl hydrate in the tank as well. as stated above make sure the car is good and hot to make sure the cat is working to its fullest when you bring it in to get tested. too bad your not OBD1 mustang O2 sensors work if you swap the plug over..if you have a friend who works at a shop see if they can get you a deal on a sensor
Old 01-08-2008, 07:43 AM   #11
jeffrie
Addict
jeffrie's Avatar
O2 sensor most likly. Replaced mine recently since it was done and I have 220K on my car, BMW suggests replacment every 160K wither it's within spec or not, since it will increased fuel milage and reduce emmisions.
PVC valves fail @ about the same time and pretty cheap & easy to replace.
Old 01-09-2008, 01:46 PM   #12
topnotchraly
Thanks for everyone's input. What I've found is that with results as bad as mine it's likely the CAT has failed. However, I'm going to change the O2 in front of the cat, put in some 94 octane and a can of 'guarenteed to pass'. I've already changed the plugs and air filter.
I'll try this and see what happens...if it failed I guess it's a new CAT then (yike$).
I didn't know BMWs had PCV values...none of my GTIs did...where is it?
Thanks,
James
Old 01-09-2008, 03:32 PM   #13
jeffrie
Addict
jeffrie's Avatar
Thanks,
James
Follow the hose from the back of the vavle cover, it goes streight to the PVC valve.
Old 11-03-2008, 11:02 AM   #14
topnotchraly
For the record, I did what I said above. Changed plugs and O2 in front of the cat, put in a can of 'guarenteed' and I passed with flying colours. Offending number went from 1100 ppm to 32 ppm.
Old 11-03-2008, 01:38 PM   #15
5style
Hatters gon Hatt
5style's Avatar
ohhh well looks like my 02 needs to be replaced, thats probably why my milage is slowly decreasing.
