Welcome to!
Old 12-29-2007, 11:48 AM   #1
broken lug bolt
i broke a lug bolt last night trying to take off a flat. How would I get out the remainder? Drill and re-tap? Is there a way without damaging the threading?
ruthmann88 is offline   Reply With Quote
Old 12-29-2007, 12:28 PM   #2
I drilled a small hole into the remainder, then hammered a old torx head screwdriver into the hole. The piece just unscrewed.
'87 325E....needs some love
"Friends don't let friends drive Hondas"
"It's more fun to drive a slow car fast than it is to drive a fast car slow."
Trevorm is offline   Reply With Quote
Old 12-29-2007, 01:09 PM   #3
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
yea that might work.. and if you have a mig welder or any welder. you could just tack weld a nut on the stub thats broken off and then turn it out.
86coupe30 is offline   Reply With Quote
Old 12-29-2007, 04:20 PM   #4
The Afro-stig
e30_kid89's Avatar
How much broke off? if its a decent amount still left just take off the wheel+rotor and some of it should still be sticking out past the hub mounting surface. Just take a pair of pliers or w/e and just turn it out by hand.
Old 12-29-2007, 04:35 PM   #5
Its rare that they get broken when taking it out, most of the time is from people over torqueing them...In your case it might be hard, because the bolt is stuck...If it was broken the other way (putting it on) they are very easy to take off (because once broken there is no pressure).
I suggest getting the tool from Canadian Tire, or any automotive place, its your best bet...(and heating it up before will also help).
Old 12-30-2007, 02:33 AM   #6
Is the wheel able to come off? Just replace the entire hub if the wheel can come off.
Old 01-01-2008, 10:30 PM   #7
Almost Sideways
u can dril it out and put a helicoil if u dont want to spend alot of cash.
