Old 12-08-2007, 12:07 AM   #1
kamus
Life begins at 4000rpm
kamus's Avatar
how far on battery + dead alternator?
if i think my alternator is screwed, and i fully charge the battery, and then start the car by rolling down a hill (to save the charge) how far can i drive before the battery dies?
I wanna know if I can get it to my prefered shop to check/replace the alternator.
And what if I start with the ignition - how far then?
kamus is offline   Reply With Quote
Old 12-08-2007, 10:34 AM   #2
supernaught
supernaught's Avatar
not far, and a lot less than not far if you use the starter, maybe nowhere.
Old 12-08-2007, 10:35 AM   #3
supernaught
CAA is cheap I just got a car towed 160kms no $$ out of my pocket
Old 12-08-2007, 10:37 AM   #4
Quack
Wheelman
Quack's Avatar
anywhere between 10-20 mins, maybe more if you're lucky
Quack is online now   Reply With Quote
Old 12-08-2007, 10:56 AM   #5
ThatOneM42
Send a message via AIM to ThatOneM42
if ur battery light comes on when you turn on ur car, its most likely ur alternator.
if ur goin to do it, turn off ur cdplayer, headlights, try not to use ur brake lights or signal lights lol...this might help you just a bit more. or just be safe and get CAA.
ThatOneM42 is offline   Reply With Quote
Old 12-08-2007, 12:00 PM   #6
It's very risky and impossible to tell how far for sure.
Either take a chance or play it safe and have it towed.
Dare I squeeze
Old 12-08-2007, 12:03 PM   #7
thatguy
easy disconnect the fuses for almost all the accessory for the car except the DME. u should make it very far, 1-2hour drive.
thatguy is offline   Reply With Quote
Old 12-08-2007, 12:45 PM   #8
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I made it 40 mins home on a dead alt and a dying battery. It ran out of juice 2 KM from home
Old 12-08-2007, 05:46 PM   #9
kamus
kamus's Avatar
I have CAA but have already used them 3 times this year, twice for me and once for a friend.
Also is this a valid test: If I get the car started, and then disconnect the battery - a 'good' alternator would keep the car running right? So that might tell me it's the battery that's screwed.
The reason I'm not sure which is because this battery sat dead for the six months while waiting for my recent engine swap. And if these questions sound silly, it's because I don't have a voltmeter etc. to do the obvious
Thanks everyone!
Old 12-08-2007, 05:56 PM   #10
e30_kid89
The Afro-stig
e30_kid89's Avatar
No No! I hear pulling the battery while the engine while running can fry some electronics...
Old 12-08-2007, 06:03 PM   #11
BmW1819
hook up a multimeter when your car is just sitting there it should be around 12.1- 13.0 volts start your car it should jump to at least .5 more than it start for example it starts at 13.0 volts it should at least charge to 13.5 . that's just a quick test
Old 12-08-2007, 09:54 PM   #12
calegrant
I'm experiencing a few battery/alternator issues ATM but I'm not sure how to distinguish who the culprit is. When I start it at 630 am around 0 degrees the lights are really dim, when I give it gas they go to pull brightness. When the rpm's drop down to idle the lights dim as well. After about 5 minutes the problem goes away. I"m assuming it's battery related because of the cold but thought I'd ask to be sure.
calegrant is online now   Reply With Quote
Old 12-08-2007, 10:22 PM   #13
^ Voltage regulator
Rippin' Proper | E30 | E36 | E36 M3 | E36 Ti |
Old 12-09-2007, 12:30 PM   #14
BmW1819
^ Voltage regulator
agreed
Old 12-09-2007, 07:48 PM   #15
calegrant
The voltage regulator is located behind the alternator and is a simple replacement correct? If I were to go down to lordco is there a specific part # I'd need to have, I assume bosch would be my best bet for a replacement.
