Old 12-05-2007, 04:24 PM   #1
Spoose
What is the smallest rim size for a 04 330i
Can I use a 16" rim on a 2004 330iA. I overhead I can only use 17" rims, is that true?
Spoose is offline   Reply With Quote
Old 12-05-2007, 06:45 PM   #2
wvt
i believe it is 17s but there was one 16 that was able to fit . . the reason the most 16s cant fit is because of the size of the brakes.
wvt is offline   Reply With Quote
Old 12-05-2007, 11:27 PM   #3
Spoose
that's what I heard, that I can only use 17" but someone told me I can use 16" as long as they clear the brakes. I guess I will need to test fit.
Old 12-06-2007, 07:00 PM   #4
Karim@Corner73
Karim@Corner73's Avatar
You're right. Most 16's won't clear the calipers. Some do
Karim.
Old 12-06-2007, 08:52 PM   #5
This is a quote from Jay. These are for an e36 m3, but if i had to guess i'd say these are the 16s that would most likely fit.
Originally Posted by Mystikal
Nothing OEM will fit, at least without spacers.
Aftermarket 16's that work:
Mille Miglia Spider
Mille Migle MM-112
AT Italia Type 5 (Contour reps)
ASA JH3
The ASA is still sold new by Tirerack, the rest are no longer available.
Old 04-08-2008, 10:43 AM   #6
tchung
I have a set of 16" AT Italia Type 5 (Contour reps) and they would fit a 330i. However, care must be taken when balancing the tires. The stick-on wheel weights must be applied to the front of the wheel instead of the inside of the wheel. This is to make sure that the stick-on weight does not touches the brake component.
tchung is offline   Reply With Quote
Old 04-08-2008, 05:10 PM   #7
Mikeee46coup
If you're looking for cheapies, tirerack.com has a few 16" wheel styles that will clear 330 brakes, I don't believe any OEM BMW wheels will though.
DPE Wheels, H&R Cupkit, M3 Interior...too many mods to list.
Mikeee46coup is offline   Reply With Quote
