Old 11-18-2007, 02:14 PM   #1
gtiperf
will the wheels fit
does anybody know if the wheels on a 2004 5 series will fit a e34?
gtiperf is offline   Reply With Quote
Old 11-18-2007, 05:02 PM   #2
talltorontoguy
Go Topless
talltorontoguy's Avatar
E39 will fit with use of centering rings (up to 2003), I don't think later models will fit.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 11-18-2007, 05:20 PM   #3
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
They will fit, provided they are not crazy wide rears.
Old 11-19-2007, 09:15 PM   #4
Old_School
You need to make sure the offset (where the hub connects in relation to the rim), rim width and hub size are compatible. You can get hubcentric rings for wheels with larger size than the hub (E39 and newer are larger than the E34). Where you can run nto problems is if the rim width and offset end up either causing rubbing on the suspension (nothing you can do about) or running on the fender (you can trim or roll your wheel-wells).
Best bet is to try one for fit, on the front and rear, and make sure nothing is going to interfere.
A bunch of 20+ year old cars.
Old_School is offline   Reply With Quote
Old 11-19-2007, 11:56 PM   #5
I'm pretty sure that only the e39 are different hub size (74.1mm). The newer yet 5 series went back again to the 72.5mm hub, and all 5/7 series rims are the same relative offset, with accommodations for rim width.
I test fitted some 16" e60 5er rims on my e34 last year, no problems (and they looked sweet).
I'm running e39 rims on my e34 with centering rings.
The tire sizes may not be correct from e60 to e34, but then again I'm running 245/45/17 (way too large) and I find they're great, other than the piss poor fuel economy I get.
Old 11-20-2007, 12:06 AM   #6
Gamite
Gamite's Avatar
Hound had E60 wheels on his E32. So they should fit on an E34. E34 and E32 wheels are the same.
www.gamite.net
Old 11-20-2007, 12:37 AM   #7
Axxe
Axxe's Avatar
E38, E39, and X5's (first gen 100%, not sure about second gen) used the 74.1 mm centerbore. All other 5x120 BMW use the 72.6 mm centerbore. Like I said originally, if the rear doesn't have crazy offset (like 545/550 sport pack rear wheels with 275 steamrollers) they should fit without issue (with the proper height tire of course). It all depends on the wheel specs, the car you put it on (lowered, BBK, etc) and the size of the tire.
Old 11-20-2007, 01:44 AM   #8
E38's are 72.56mm.
E53 (first gen) X5's are 72.56mm.
E70 (second gen) X5's are 74.1mm (only chassis the same as the E39 centerbore).
To answer the original question again, yes, the wheels will work fine.
Old 11-21-2007, 09:49 AM   #9
denisemichel
AMG LOL
denisemichel's Avatar
yup they should fit because i've seen a E34 not to long ago in sauga with some E60 wheels.
01' BMW 530i Sold................................03' Lexus GS430 Sold...........................06' BMW 750i
denisemichel is offline   Reply With Quote
