11-16-2007, 05:37 PM
#16
Addict
Car: 97 318 IS
If you got stiffer aftermarket valve springs you could raise your rev limiter if you wanted too.
I's also add the upper and lower spring plates to the list & I'd also pick up new valve collets.
Think your alright with that list except for the coolant.
1 gallon is about 4L + another 4L of distilled water = 8L of antifreeze.
Your car needs 11L's of coolant that is if you do not spill any.
Your block will probably hold the missing 3L if you do not drain it all out via the bolt under the manifold but I'd buy more just to be safe, as it looks like you plan to keep your car for awile.
11-22-2007, 07:58 AM
#17
Car: m3
Originally Posted by Mickey Knox
ok, below is my shopping list of parts to do some maintenance to the head/valve train. I plan to ttake the head off and bring it to a machine shop to have it measured and leveled, valves ground and refitted. anybody here that can get me this stuff cheaper? Did I miss any parts? Any parts on here i dont need?
- 11-12-9-064-467-M17 Head Gasket Set, E36 325i/is/iC from 9/92 Brand: Victor Reinz $150.50
- 11-12-1-721-938-M17 Cylinder Head Bolt Set, 323i/is/iC 1996-99, 325i/is/iC 1992-95, 328i/is/iC 1996-99, M3 1995-99 Brand: Victor Reinz $14.75
- 11-34-9-064-457-M42 Valve Stem Seal Kit, 323i/is/iC 1996-99, 325i/is/iC 09/92-95, 328i/is/iC 1996-99, M3 1995-99 Brand: Goetze $10.25
- 24 X 11-34-1-738-488-BOE Valve Spring, 325i/is/iC 09/92-95, As Needed, Each Brand: Genuine BMW $186.00
- 24 X 11-12-1-735-534-M105 Valve Guide, I.D. 6 mm 12.73 mm, 43 mm Length, E36 325i/iC/is from 9/92, 318i/is/iC from 9/92, 323is/iC, 328i/is/iC, 318ti, M3 B30/B32, Each Brand: $138.00
- 24 X 11-32-1-739-299-M40 Hydraulic Lifter, 318i/is/iC With M42 Engine 1992-95, 325i/is/iC 09/92-95, Each Brand: INA $420.00
- 11-31-1-405-081-M40 Chain Tensioner for Crankshaft to Exhaust Cam Chain, M3 With 3.0L Engine 1995, upgrade for 325i/is/iC w/ M50 motor and 328i/is/iC w/ M52 motor, Each Brand: Ina $173.25
- TOL-3017 Camshaft Holding Tool/Fixture includes 2 blocks 1 swivel lock and 1 flywheel locking pin, Fits M42, M44, M50, M52, M54, S50, S52 Engines, $145.70
- 83-30-0-493-548-BOE Tensioner Pressure Tool, For BMW S50, M50 and M62 Engines, service manual reference #11-3-390, Each Brand: Genuine BMW
$37.00
- 2X 82-14-1-467-704-M9 Genuine BMW Antifreeze, 1 gallon Brand: Genuine BMW $39.00
- PEL-SW50189 Red Line Water Wetter, 12 oz.
thx
mickey
Just wondering, where are those prices from?
11-26-2007, 08:42 AM
#18
Car: 1993 325is
pelicanparts.com
prices from pelicanparts.com
11-27-2007, 08:47 PM
#19
Car: m3
btw, I just ordered headgasket set for my car and this
was included in the set.
