Old 11-12-2007, 09:37 PM   #1
sicilianace
E-thirtysexer
sicilianace's Avatar
Send a message via ICQ to sicilianace
Wiring 2- 4ohm subs to a 2-channel amp.???
guys, is this okay to do, i have a 2 channel amp but can i wire my 2- 4ohm subs Rated (150 rms each) to the one channel only.....so i get more wattage ??????
amplifier info: 97wRMS x 2channels @ 4ohms
142wRMS x 2 channels @ 2ohms
283wRMS x 1 channel @ 4ohms
thanks, help
e36 325is
e30 m3
sicilianace is offline   Reply With Quote
Old 11-12-2007, 11:24 PM   #2
archrival
E36 Addict
archrival's Avatar
is the amp bridgeable if so then yes you are safe...im guessing since you have the ratings then it is
archrival is offline   Reply With Quote
Old 11-12-2007, 11:38 PM   #3
ZiMMie
so that means that amp can push over 500RMS @ 2ohms.
since u r not going to be running the amp @ full all the time,
wire the subs into a 2ohm load and feed it to the amp Bridged.
Post the model # of the amp.
and ill let u know how far u can push it to.
Remember its always better the feed the subs more power then less power.
#E36-S54 #CSLWannabe
Old 11-13-2007, 12:21 AM   #4
sicilianace
E-thirtysexer
Zimmie, its a infinity amp model #7520A
e36 325is
e30 m3
