Old 11-14-2007, 08:16 AM   #16
jeffrie
Addict
jeffrie's Avatar
Raising rate fuel pressure regulator, that's it.
On full Boost fuel rail pressure holds @ 90 PSI.
I can only burn 91+ octane fuel with my stock 10:1 compression.
Then again that's all I burned before FI aswell.
I do plan on tuning and bigger injectors for when I go to 10 PSI.
Old 11-14-2007, 08:59 AM   #17
blk325i
blk325i's Avatar
well i brought it into the shop last night and checked fuel pressure it was sitting at 44psi idle, tryed adding more fuel since i'm using fuel pressure regulator didn't get anything(couldn't trun it up or down) it's like it didn't even work, so what i found out that oe fuel pressure regulator is actually regulated by ECU and ECU wouldn't let me get more fuel into the system so i bypassed the oe fuel pressure regulator and now i can turn fuel up which i did and works a lot better as per Engine light was for bad mixtures in bank 1 and bank2.
Does anybody what the fuel pressure should be at idle and when i'm boosting
BTW i'm not planing on boosting more then 6psi anyways for now.
blk325i is offline   Reply With Quote
Old 11-14-2007, 09:16 AM   #18
SickFinga
SickFinga's Avatar
44psi is 3.0 bar, you should be at 3.5 or 51psi.
Do you have OBDII tool? If you do, check your STFT and LTFT.
Old 11-14-2007, 01:43 PM   #19
blk325i
blk325i's Avatar
i should be at 51psi at idle and when i stepon it what should it go up to?? i got little bit more pressure right now i think i'm at 60psi at idle. i found a guy localy that is going to tune it a bit for me on the stock computer, he's got a wide band that can be hook up to any car so we can play around with air/fuel mixture.
btw do you guys know anybody that will tune the ECU in the ontario??
Old 11-14-2007, 02:44 PM   #20
SickFinga
SickFinga's Avatar
First get appropriate injectors for you car. Tuning your software without them is just a waste of time and money.
Before you do anything with your tuning that came with the kit, find out if previous owner had similar problems, if he didn't then your tuning is fine and something is wrong with your install.
Old 11-14-2007, 03:54 PM   #21
blk325i
blk325i's Avatar
i'm trying to get hold of a guy that i bought it from so i can see if the ECU was ever tuned to begin with, second i think the stock injectors are fine for only 6psi because i got buddy with 328 turbo boosting 10psi on stock injectors and the car is running fine but he is running a biggyback system. but i will look into getting another set of injectors but i just scaned the car for codes and i'm running too rich all 4 oxygen sensors are showing that they are running rich, plus i think i found a leak between a throtle body and manifold so i got to look into that too.
thanks
Old 11-14-2007, 04:17 PM   #22
SickFinga
SickFinga's Avatar
Stock injectors are definitely not fine. If a simple 3.5" hfm swap requires 24lbs injectors, a boosted car definitely requires bigger injectors.
Right now I have 36lbs injectors and I just ordered 42lbs for my 11psi m3.
Did you install boost gauge? How much psi are you getting?
The only person I know that can do OBDII tuning in Ontario is MarkD
Old 11-15-2007, 12:11 PM   #23
blk325i
blk325i's Avatar
do you want to get rid of yours 36lbs injectors if so how much
i havent got the gauge in yet i will today or tomorow
and i have spoke with markD already work in progress.
thanks
Old 11-15-2007, 01:16 PM   #24
SickFinga
SickFinga's Avatar
thanks
I will be selling them soon, but 36lbs might be too much for your application.
I might be selling them as a package though, 3.5"hfm, injectors and ECU.
I'll let you know when I'll get my 42s.
Old 11-15-2007, 02:08 PM   #25
blk325i
blk325i's Avatar
would all that work on my car? what size injectors i should be looking at??
one more thing i just came back from bmw where i had my EWS done but they flushed the ECU that i got with the car so i'm working on the deal with them to get me dinan software put back into the my ECU they will let me know today. Would that work with ERT setup (dinan software)?
btw how much would you be looking for your package??
thanks
Old 11-15-2007, 02:09 PM   #26
blk325i
blk325i's Avatar
hey sickfinga whats STFT and LTFT??
Old 11-15-2007, 08:16 PM   #27
JMW
Pole busted to boosted.
JMW's Avatar
what colour is ure caR? maybe i saw it when i was at laurier (went to uni there) have a silver boosted m3 with a cf hood
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
JMW is offline   Reply With Quote
Old 11-15-2007, 09:01 PM   #28
SickFinga
SickFinga's Avatar
thanks
36lbs injectors are too much for 6psi setup.
I think Dinan kit came with 28lbs injectors.
Dinan software should work, what you got is pretty much an early version of the Dinan kit.
STFT is Short Term Fuel Trim
LTFT is Long Term Fuel Trim.
Any OBDII scan tool should be able to show you those values.
Old 11-15-2007, 11:52 PM   #29
MarkD
MarkD's Avatar
thanks
What's wromg with those guys that aligned the EWS? Why did they erase your software? You don't need to erase it to align the EWS. I'd say they don't know what they are doing!
Old 11-16-2007, 09:09 AM   #30
blk325i
blk325i's Avatar
i don't know why they reflashed the ECU i would say that they didn't know what they were doing but it really doesn't matter right now i think kit is up for sale i got cought last night for "racing" 52 over the limit i need money to fight it. F**cking ontario law!!!
