Old 11-12-2007, 11:37 AM   #1
blk325i
blk325i's Avatar
supercharger question
i bought a used ERT supecharger kit for my 97 m3 had it installed last night, pluged the computer in the car wont start, take that one out plug my original computer car starts. Drove the car around last night and every time i throttle it and than come to a stop sign car will shuts off.
what i wanted to ask is if anybody knows anybody that can program the OBD2 m3 computers for this settup??
thanks
blk325i is offline   Reply With Quote
Old 11-12-2007, 05:10 PM   #2
SickFinga
SickFinga's Avatar
with another ECU, does your engine turn over when you try to start it?
Old 11-12-2007, 06:41 PM   #3
blk325i
blk325i's Avatar
yup it starts
Old 11-12-2007, 07:02 PM   #4
SickFinga
SickFinga's Avatar
Originally Posted by blk325i View Post
yup it starts
I mean does engine turn over with ECU that came with the kit?
Old 11-12-2007, 10:53 PM   #5
NOTORIOUS VR
NOTORIOUS VR's Avatar
thanks
You shouldn't be boosting a car with the stock ECU... the timing and fuel maps need to be adjusted. Did the other ECU (or the S/C) come with different injectors? It might be that the injector pulsewidth on the ECU that came with the S/C is too small for your original injectors resulting in the car not getting enough fuel to start. Either that or the ECU is dead/bad.
Old 11-13-2007, 03:29 AM   #6
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
Originally Posted by NOTORIOUS VR View Post
You shouldn't be boosting a car with the stock ECU... the timing and fuel maps need to be adjusted. .
for the sake of a 'perfect tune' i'll agree...
but i've been driving my boosted car on its stock ecu (and others) for 2years.
it seems to adapt ok up till 12lbs. so a stage 1 sc should be ok.. but not 'perfect'
what no1 should do is drive a boosted car without extra fueling and a A/F & boost gauges
Old 11-13-2007, 03:34 AM   #7
jeffrie
Addict
jeffrie's Avatar
^^^ I agree, been driving with 8 PSI and stock ECU managment for over a year with no issues @ all, fuel milage has bearly even suffered.
I'd put stock ECU back in and let it compensate.
Old 11-13-2007, 11:42 AM   #8
blk325i
blk325i's Avatar
the car doesn't start with the ecu that i got with the kit, which i found that i have to do EWS align which i did yestarday and the car starts with the ECU that came with the kit after EWS, but on the way home the engine light came on and the car wont stay running at idle, if i drive it normally the car will run but soon as i step on it and come to the stop the car will die on me, but if i drive it normally the car will stay running at like 500-600 rpm. i didn't get no bigger injectors with the kit but i got rasing fuel pressure regulator with it. i think the car is running to rich and thats why i keeps shuting off on me when i punch it i'll hook up a fuel gauge to it tonight to see what it is running at.
So is it true that i can run a system on the stock ecu or i have to get it tuned. the kit was only suppostu be 6-6.5 psi??
thanks
Old 11-13-2007, 12:50 PM   #9
SickFinga
SickFinga's Avatar
Sounds like you got a vacuum leak somewhere.
Old 11-13-2007, 01:17 PM   #10
blk325i
blk325i's Avatar
i will bring the car in the shop tonight to check for vacum leaks and to check fuel pressure. What fuel pressure should be at?? It's a 97 m3 with ERT powerdyne supecharger. stock injectors and with rasing fuel pressure regulator.
thanks
Old 11-13-2007, 02:32 PM   #11
SickFinga
SickFinga's Avatar
Well, stock fuel pressure on your car is at 3.5 bar.
With your setup you should be running about 30lbs@3.5 injectors.
Right now you have 21.5lbs
You really should get injectors, they are not that expensive.
Old 11-13-2007, 03:54 PM   #12
blk325i
blk325i's Avatar
thanks man i'm going to check that out tonight and i found a guy that has a scan tool for bimmers so i'll check the engine light too to see what its saying
Old 11-13-2007, 08:30 PM   #13
blk325i
blk325i's Avatar
can i run a stock pressure regulator and the one that i got with the kit at the same time?? i checked fuel pressure and the one that i got with the kit doesn't do anything
Old 11-13-2007, 09:11 PM   #14
NOTORIOUS VR
I don't like to rely on knock sensors to have to pull back the timing because of detonation. Especially since knock sensors aren't all that good in detecting knock at high RPM. Also, stage 1 S/C kit's are usually non intercooled, where IMO it's even worse not to have a proper chip as FI = higher intake temps which means you're more prone to detonation again.
I'm not saying it wouldn't work... but the absolute most I'd boost is 6psi on a stock ECU/motor combo. But that's just me.
As for extra fueling, how will you get that with a stock ECU? The only way would be an FMU/RRFPR, which again would work but not the most efficient way to get power out of your setup.
Old 11-14-2007, 12:36 AM   #15
NOTORIOUS VR
I just stumbled onto this threat over at BF:
http://forums.bimmerforums.com/forum...d.php?t=870693
kinda answers most of the questions here, and tells you exactly why you shouldn't be putting boost on a stock ECU'd car.
What have you done for fueling btw?
