Old 11-04-2007, 10:52 PM   #1
6appeal
6appeal's Avatar
Stock Digital Speedo on E36
I saw a video once where a guy somehow made his odometer display read the speed the car was going. It would increase and decrease accordingly. Anyone know what I'm talking about?
6appeal is offline   Reply With Quote
Old 11-05-2007, 07:43 PM   #2
98Dinan3
98Dinan3's Avatar
hold the odometer rest button and turn the key to position 2. The display will show test #1. Press the button repeatedly until you get to number 14. Press the button one more time and hold it on # 15. It will say " Lock ON" and switch to "lock off" after a few seconds. Try out the various test numbers. There is a digital speedo, tach, etc... BTW...I think this is only on OBDII clusters.
Old 11-05-2007, 07:50 PM   #3
beskhu3epnm
beskhu3epnm's Avatar
Send a message via MSN to beskhu3epnm
These can be unlocked if you have a newer E36.
Instrument Cluster Functions
Never tried it, I only have a 96, so the first 6 tests are available (or something like that).
96 328i Mods - Rusted Subframe, Slipping Auto, Old Motor, Schrick Intake Manifold, OEM Muffler Full-o-Holes, aFe CAI,
Broken Heater Valve, HID @ 5000K, Failed Pinion Bearing, Coolant Leak, Euro Ellipsoids, Smoked Euro Tails,
Oil Leak, M Side Mouldings, Sandblasted Front Bumper, Power Steering Leak, 18x8 Italia Inox (2 Bent),
Cracked Foglight Mod, Plastic Fan Blade Mod, M3 Bushings, Girlfriend Delete Mod (GDM), Vacuum Leak Mod
beskhu3epnm is offline   Reply With Quote
Old 11-05-2007, 08:44 PM   #4
6appeal
6appeal's Avatar
ah. all very interesting. I have a 98 so it should work. I'll give it a try, thanx!
Old 11-06-2007, 12:05 AM   #5
Singe
BGDorcol
Singe's Avatar
wow newer knew this, these cars are amazing i love it hehe
Singe is offline   Reply With Quote
Old 11-07-2007, 03:33 PM   #6
6appeal
6appeal's Avatar
It worked! Too bad I can't save the display to the test# that I want. You have to do the process before each time you start the car. Ah well. Cool enough
Old 11-07-2007, 06:38 PM   #7
slemmer
Driving in the fast lane
slemmer's Avatar
Yep, and as 98Dinan3 said earlier, it's a good way to re-align the needs on the tach and speedo if they're way off.
Old 11-07-2007, 10:44 PM   #8
someguy
Singhy
i have a 95
someguy is offline   Reply With Quote
Old 11-12-2007, 02:25 AM   #9
6appeal
6appeal's Avatar
How would one re-align the needles? I have noticed that my speedo reads a good 5-9 kms higher than the display.
Old 11-12-2007, 09:56 PM   #10
slemmer
slemmer's Avatar
slowly pull up to release the seating from the post and re-attach with a push down motion.
Old 11-20-2007, 10:34 PM   #11
beskhu3epnm
I did a DIY on adjusting the speedometer needles here:
http://forums.bimmerforums.com/forum...d.php?t=875056
My speedo is in metric, and it was driving me insane the amount that it was off (120km/h = 110km/h). I'd had enough and fixed it. Works like a charm.
I don't have the test functions that the newer ones had, so I improvised!
