Old 11-04-2007, 12:54 AM   #1
vegabass
How do i shift gears?
vegabass's Avatar
Amp and Subs Question?
Ok guys, a friend of mine has a JL 1000/1 and already has a ID MAX 12" sub. I think it pounds like hell. He wants to go with another one cause he thinks it will play louder. I think it would not make a difference if he added another sub because instead of one sub getting 1000 watts, it would be split 500 watts a sub then. I dont know if that makes sense or not? Please help.
vegabass is offline   Reply With Quote
Old 11-06-2007, 09:00 PM   #2
vegabass
vegabass's Avatar
anybody??
Old 11-06-2007, 10:16 PM   #3
FuryriderX
cra.iX.y
FuryriderX's Avatar
ok well ill take a stab at it. and yes your question makes sense.
subs have a recommended power rating, that they'll sound their optimum at. i dont know what it is for the ID MAX. you have a point, that the power will be split 50/50, the issue is, will you still be powering both subs optimally.
doubling the subs = doubling piston area = louder. but only if the amp can drive them.
find out what the recommended power is for the ID MAX, if its 5-700, then go get another one and pound away. but if its 1000+, then you'll be underpowering them and while they may be louder, they wont sound as clean/crisp.
hope that helped!
Old 11-06-2007, 10:21 PM   #4
328IScreamer
328IScreamer's Avatar
he hit the nail on the head.....the surface area of the sub is a key part of what makes it louder which is why 12's are usually louder than 10 ect... the JL 1000/1 is one of the best amps going and can be tweaked in just about every way so make sure your buddy knows what he's doing when setting up the amp to 2 subs vs only one sub. Also ported box's are generall louder than sealed but i would never recomend a ported box, they sound sloppy and don't have as much range
328IScreamer is online now   Reply With Quote
Old 11-07-2007, 12:49 PM   #5
vegabass
vegabass's Avatar
hope that helped!
http://www.imagedynamicsusa.com/prod...idmax&type=sub
It makes sense, the recommended power range should be about 600 rms according to the website.
thanks for the help.
Old 11-07-2007, 12:56 PM   #6
vegabass
vegabass's Avatar
What would you recommend for a hook up, If both subs were dual 2 ohms, what do u think would be the optimal connection to the amp. The amp i believe is stable anywhere from 1.5 to 4 ohms.
thanks for ur help in advance.
