Old 10-30-2007, 05:54 PM   #1
mayo
FS: MSD 7AL-2 box with coil $250
MSD Ignition Control Box 7AL-2 Race Ignition with Rev Limiter - 7224
Item number 4657
MSD 7AL-2 Race Ignition set the high standards that other racing ignitions still try to reach. Like the MSD 6 Series Ignition, the MSD 7AL-2 is a capacitive discharge design, meaning it has a large capacitor that stores high voltage and discharges all of it's energy into the coil. This design produces extremely hot sparks and a quick recovery time for the coil.
The MSD 7AL-2 uses its multiple spark discharge circuity to keep the engine clean at low rpm for better throttle response, off corner performance, smooth idle and more consistent launches. This spark series lasts for 20 degree crankshaft rotation through 3,000 rpm. This long duration combined with powerful, capacitive discharge sparks ensures ignition of the hard-to-ignite fuel mixtures of a race engine. The built-in Soft Touch Rev Control feature of the MSD 7AL-2 will protect your engine from over rev damage in the event of a missed shift or driveline failure.
Adjustments are easily made with plug-in modules. At your selected rpm, the Soft Touch begins dropping the sparks to some of the cylinders and on the next cycle these same cylinders are fired to prevent fuel from loading up in the cylinder.
The result is a smooth and accurate limiting action without backfires or roughness. The MSD can be triggered from points, magnetic pickups, crank triggers and electronic amplifiers.
Suitable for 4 Cylinder Cars only
Retailed for : $786
visit http://www.gtaparts.com for all makes and models parts for sale!
mayo is offline   Reply With Quote
Old 10-31-2007, 09:58 PM   #2
mayo
ttttttttttttttttt
Old 11-21-2007, 04:47 AM   #3
mayo
ttttttttt
Old 12-01-2007, 03:11 PM   #4
mayo
ttttttttttttttt
Old 12-04-2007, 08:52 PM   #5
mayo
ttttttttttt
Old 12-13-2007, 11:16 PM   #6
mayo
ttttttttttttttt
Old 12-20-2007, 03:25 AM   #7
mayo
ttttttttttttt
