Old 10-24-2007, 09:28 PM   #1
calegrant
Shifting w/o clutch
While driving home from work today my foot slipped off the clutch but I carried through with the shift and it popped right into 4th. I've heard of people shifting w/o a clutch before but I figured it was just idiots wrecking their cars. So like the moron I am I decided to experiment a little. By the time I got home I could smoothly shift through all gears including 1st-> 2nd. Is this going to damge my tranny in the long run? I didn't grind any gears, and it seemed to pop in really easly when I got the rev's matched properly. Is this a sign of wear that I'm not aware of?
Old 10-24-2007, 09:55 PM   #2
Striker
Turbo Ready
Striker's Avatar
I have been showing people for fun how it can be done, both up shifting and down shifting.
I can do it with any car with a syncromesh gearbox, just have to feel for the engagement. You are not really damaging anything if the gears are not grating or jumping into gears with a jerk, but it's not a good practice.
Back in the Caribbean we had many cars with cable clutch systems, no hydraulics so the cable would snap without warning. The easiest way to get home was to start the car in 1st gear (hard on the starter) and then shift clutchlessly home Good ol days.
It's not a sign of wear but don't do it, it takes lots of practice to get it right. I have shown people how it can be done on my e46 325is, they sometimes can't believe it can be done but I was doing this since i was like 15 over 20 years ago
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 10-24-2007, 10:19 PM   #3
calegrant
Didn't take much practice for me. Didn't grind a single gear in the 15km drive home. Seemed pretty easy when you knew what rpm's the car had to be at for the up/downshift, then just had to feel it till it popped in. Almost shifts itself.
Old 10-25-2007, 12:21 AM   #4
SamE30e
SamE30e's Avatar
It's not that hard to do. I think it's hard on the syncros though.
91 318is - M50NV (gone)
85 - 325
Old 10-25-2007, 12:28 AM   #5
BigD
the misanthropist
BigD's Avatar
This topic has been covered to hell and back but the short answer is yes you are. Synchromesh gearboxes are designed to be shifted with the inertia of the engine disconnected, period.
Yeppers.
Old 10-25-2007, 01:00 AM   #6
hadesm5
hadesm5's Avatar
i thought e30 trannys are only syncro'd between 4 and 5
hadesm5 is offline   Reply With Quote
Old 10-25-2007, 02:12 AM   #7
Eurostyle
Eurostyle's Avatar
Yeppers.
Then how come all truck drivers dont clutch, and the transmission last over a million Km....?
Eurostyle is online now   Reply With Quote
Old 10-25-2007, 09:22 AM   #8
Striker
Turbo Ready
Striker's Avatar
Had a Ford Capri (1974 model) had a bad clutch and did shift without clutch for nearly a month whenever the clutch did not build enough pressure. I fixed the clutch, gave the car to my brother who used it for another 8 years until he crashed it in 1994. I NEVER had to replace the syncros in the gearbox.
I have been rebuilding gearboxes since 1985 and trust me, synchros are not damaged by shifting w/o clutch if properly matched, low and bad oil is the main reason why they do or pulling weight exceeding the max permissible weight of the vehicle.
I had buddy with the same car in 1987, he used to haul a trailer with his daily, had to do his synchros
I am not saying people should drive like that, I wrote it in all my replies, but they can last if done periodically.
Old 10-25-2007, 09:57 AM   #9
Max_VQ
Max_VQ's Avatar
The job if the syncro is to match the speed of two gears just before the engage.
If the driver can match the speed of the vehicle and engine RPM, you are doing the job of the syncro. No extra wear or damage.
Old 10-25-2007, 10:09 AM   #10
BigD
the misanthropist
BigD's Avatar
Truck drivers not only clutch but double clutch. And they don't have synchros, so the drivers skilled enough to rev match have no fear of wearing them out.
Striker: I agree that in the short term it probably won't make any difference, especially if the person is skilled and dilligent enough to get the revs matched closely. But in the long term, they will still wear because no one's good enough to match them 100% perfectly, which is why non-synchro boxes have wider windows for the dogs right? And I don't know about you but I'd much rather change the clutch than rebuild or buy a transmission. Besides, if you shift properly, the clutch will last longer than you'd probably keep the car.
Old 10-25-2007, 10:26 AM   #11
Eurostyle
Eurostyle's Avatar
^^^Yes they do have syncros, and good drivers dont clutch other then when taking off...
Old 10-25-2007, 10:44 AM   #12
What's the point? Rev matching under full acceleration is not faster since you need to wait for the revs to drop, and that's the only time you'd benefit from any decrease in shifting time. Freeing up a foot is only worthwhile if you can't heel-toe, and in an e30, heel-toe is simple with practice.
I suppose it might be handy to shift while holding your coffee and steering with your left leg. Which I do.
everlast is online now   Reply With Quote
Old 10-25-2007, 10:45 AM   #13
El Gato Liso
El Gato Liso's Avatar
so when u get the perfect revs
do you have to come off the gas when u shift without the clutch
or do u just keep the gas when u shift
if u get the correct rpm and u come off the gas, wouldnt it drop a bit thus not getting the right rev match? or do u rev beyond that point so when u shift the rpm drops to that correct point
***E30 part out to come. Gimme a PM for any inquiries!***
Old 10-25-2007, 11:25 AM   #14
BigD
the misanthropist
BigD's Avatar
Prove it. Here's mine:
http://en.wikipedia.org/wiki/Manual_..._transmissions
No they don't, not here. In Europe or wherever they don't have weight limits and uber strict policing, maybe.
Originally Posted by Wikipedia
Heavy duty trucks utilize unsynchronized transmissions in the interest of saving weight. Military edition trucks, which do not have to obey weight laws, usually have a synchronized transmission. Highway use heavy-duty trucks in the United States are limited to 80,000 pounds GVWR, and the lighter the curb weight for the truck, the more cargo can be carried, and with a synchronizer adding weight to a truck that could otherwise be used to carry cargo, most drivers are simply taught how to double clutch.
Old 10-25-2007, 11:38 AM   #15
Furious
BMW again.
Furious's Avatar
nothing beats real world experience in which it looks like the only person whos had enough of it is striker.
i dont believe everything i read on wikipedia.
