Old 10-23-2007, 01:34 PM   #1
bimmerod
F/S Water pump / 98 M3
I went to change my water pump to the type with the metal impeller only to find out it had already been changed.
I changed it anyway.
F/S Water pump from 98 M3 w/metal impeller
$50 OBO
bimmerod is offline   Reply With Quote
Old 10-23-2007, 06:17 PM   #2
JongExr
JongExr's Avatar
water pump
can i used that for my 1993 325i pls let me know thanks
JongExr is offline   Reply With Quote
Old 10-23-2007, 06:21 PM   #3
So, you're selling a used waterpump?
Old 10-23-2007, 08:28 PM   #4
Swerve
///Maquina
Swerve's Avatar
lol, I did the SAME thing! I got the pump out and said, "!@#!@$.... well, I'm here now, so might as well put the new one in...." So now I've got a perfectly good waterpump sitting around too
bought my car used with no idea if the pump had been changed. had i left it, it would have been the original plastic crap pump that crapped out in the middle of california's 38 degree heat. so I bought it, and sure enough i didn't have to... just my luck.
95 Madeiraviolett/Dove Grey 325is
///M3 body | Painted kidneys | Hartge spoiler | DJ Autos+DDM HID, DRL delete, clears
Hartge Nova 3+Kumho Ecsta SPT / Hamann HM2+Kumho Ecsta ASX | Bilstein Sports, H&R Sports, KMAC plates, RE RSMs, Racing Dynamics sways, M3 RTABs | M3 Front Brakes
M3 Exhaust | Autothority chip | Cosmos v2+K&N | NGK Iridiums | E46 M knob | clutchstop | woodgrain delete | /////ALPINE, PPI, MB Quart
Swerve is offline   Reply With Quote
Old 10-31-2007, 01:14 PM   #5
bimmerod
Ya it's used.
It's a shame to throw it out as I'm sure it has low miles on it.
Best offer takes it.
Old 10-31-2007, 09:42 PM   #6
jameswbl
I thought they are prone to fail regardless of impeller...but the plastic ones do fail a hell lot faster...
the bearing fails and it creates play in the shaft...
jameswbl is offline   Reply With Quote
Old 11-01-2007, 02:42 AM   #7
thinair
moderationistismingly
thinair's Avatar
The M3 water pump is the same as any other e36 6cyl water pump, so yes it will fit a 325.
My last water pump failed at the bearing, not the impeller. It started to get loud then began dumping coolant under pressure via the shaft seals.
Old 11-01-2007, 09:22 AM   #8
bimmerod
I changed it at 100K, but it had already been changed.
Since the warrenty ended at 60K, I would guess this one has 30k on it.
