Old 10-22-2007, 12:45 AM   #1
new2bmw
power , lack of
WHAT SORT OF PROBLEMS WOULD ROB POwER? I HAVE AN 84 318I WITH THE M10, DONT LAUGH. i DROVE IT DOWN THE STREET TODAY WITH NO WINDOWS YET LOL AND IT HAD SHIT PICK UP. I HAVE NO CAT, CUSTOM EXHAUST 2.5" AND COLD AIR INTAKE ALONG WITH LONG TUBE HEADERS, SO AIR FLOW ISNT A PROB. COULD SOMETHING SMALL LIKE AN 02 SENSOR GOING BAD OR FUEL FILTER DIRTY CAUSE LOW POWER? JUST WONDERING WHAT OBVIOUS THINGS I SHOULD BE LOOKING AT. SORRY FOR THE CAPS, JUST NOTICED AND I AM NOT RETYPING ALL THIS again. cheers guys!
and please dont tell me its an m10, it has no power, because i know this car should have more pickup then it does.
new2bmw is offline   Reply With Quote
Old 10-22-2007, 12:50 AM   #2
NOTORIOUS VR
NOTORIOUS VR's Avatar
it won't be an O2 sensor... it could be a fuel filter issue, or AFM issue... does it sound like it breaking up at all? or does it drive smooth but just has no power?
did you do the timing belt on it before you drove it? if yes, maybe u'r off one tooth on the cam?
Old 10-22-2007, 12:53 AM   #3
Give the car a good, thorough tune up, then report back. Plugs, wires, distributor cap, rotor, fuel filter etc, are excellent items to address in a tune up. It probably could use it. I know its an m10, but an automatic WILL make it much, much worse.
Lol m10... sry
Edit:
Its got a timing chain. 84 318i is not the twin cam I think you may be referring to.
EDIT #2 Holy **** what was I thinking!??! m42 doesnt have a belt either Doh!... lol only the m40 and m43 do I believe... (I think they are belt driven...)
EDIT #3 Damnit. Curiosity got the best of me so I had to look it up. M40 (SOHC) has a belt, M42 (DOHC) chain, M43 (SOHC) chain, M44 (DOHC) chain.
Old 10-22-2007, 01:04 AM   #4
new2bmw
no worries
i will adress the tune up issues, and if it still doesnt go then i will burn it. jj i will just drive it around slowly till i put in the turbo, at least its cool to just cruise in a bmw.
Old 10-22-2007, 01:08 AM   #5
NOTORIOUS VR
Lol m10... sry
Edit:
alright didn't know the m10 was a chain... still even if he did (or the previous owner even-don't know if he drove it before he did all the work) the chain it could be a tooth off and that would cause the car to be real sluggish...
it also agree, a tune up would be a good idea... although from what I'm getting from the OP's post is that his car is a sled. Plugs and stuff would make the car missfire and what not, but if everything else was ok it should still "pull" ok.
Old 10-22-2007, 01:09 AM   #6
NOTORIOUS VR
the worst thing you can possibly do is boost a motor that isn't running properly in the first place.
Old 10-22-2007, 03:15 AM   #7
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
probably all the long header/ intake stuff..no seriously..
bet it has great 'top end' right, pulls ok/good above 3500/4000?
on a small displacement motor back pressure & less velocity make better low end torq for daily drivability.
in na motors
Old 10-22-2007, 01:11 PM   #8
magnus
magnus's Avatar
Have you done a compression test? My guess if compression is ok and you do a full service then you have timing issues.
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 10-22-2007, 02:47 PM   #9
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Tune up, compression test, and drive it to redline. You changed the properties of the motor by adding headers.
Oh, and it's an M10, so it's slow
Old 10-22-2007, 08:58 PM   #10
Bmwstylz
Bmwstylz's Avatar
Its having no windows that cuts the aerodynamicy of that fine Munik Legund
Installing them will create a slip-stream effect and velocity will increase exponentially.
alternatively you could just drop a bigger engine in or turbo it mannnn.. cuz mods on an old e30 make them so fast. like crazy fast lolll
"Get rich or die tryin!"
Bmwstylz is offline   Reply With Quote
Old 10-22-2007, 11:28 PM   #11
e30_kid89
The Afro-stig
e30_kid89's Avatar
Its the heavy nasty body kit that is slowing you down bro.
Old 10-22-2007, 11:32 PM   #12
LOL ouch
Old 10-22-2007, 11:39 PM   #13
Chris de la Cruz
sex, drifting & punk rock
two cylinders missing.
/thread.
www.CSCS.ca
Old 10-23-2007, 12:18 AM   #14
new2bmw
cylinders
ok i have the bentley so dont tell me to buy one please. What procedure do i use to see if all cylinders are running? also if one isnt how is that corrected? really learning on this car but i am still really new to engine work.
Old 10-23-2007, 01:30 AM   #15
bmdbley'sBro
well in the bently theres pictures of spark plug condition..
you could pop ur plugs & compare..
theres spritzing water on your wires/coil or distrib at night while running to look for arcing.
or laying em out (wires) wtih plug in it 1 at a time & firing the car see if you see sparc.
^do not hold them while doing that
then theres a compression test.
