Old 10-17-2007, 12:09 PM   #1
5JABIJ8
5JABIJ8's Avatar
E30 4bolt to 5bolt Conversions!!!
Has anyone done this before? My cousing who has the E30 wanted to know if the E36 Hub will fit into a E30. any pointer, advise would be much appriciated.
thx
(OO==[][]==OO)
5JABIJ8 is offline   Reply With Quote
Old 10-17-2007, 12:16 PM   #2
ara_yaz
Bimmer Fan
ara_yaz's Avatar
It's definitely been and can be done...not sure where to get info though...are you doing this for more wheel options?
ethirty
ara_yaz is offline   Reply With Quote
Old 10-17-2007, 12:19 PM   #3
Here is a list using e30 m3 parts.
http://www.davelength.net/car/5lug.html
Old 10-17-2007, 12:25 PM   #4
5JABIJ8
5JABIJ8's Avatar
He wants to do this for more wheel options plus for wider setup! not exactly sure what his intentions are. but I believe he wants to run 18' on it and the 18' that he is looking at are 5x120 and are not availble in 4x100.
(OO==[][]==OO)
Old 10-17-2007, 12:28 PM   #5
ara_yaz
Bimmer Fan
ara_yaz's Avatar
Personally, I think 18's are too big for an e30 (unless it's FI)...too much lag with huge wheels.
ethirty
Old 10-17-2007, 12:29 PM   #6
5JABIJ8
5JABIJ8's Avatar
Wow thx.. good find .but do you really have to change all those parts man..can't just swap hubs directly?
(OO==[][]==OO)
Old 10-17-2007, 12:34 PM   #7
5JABIJ8
5JABIJ8's Avatar
I told him to go with 16's at the most 17's as that is more than enough for the E30's even then he still wants to convert from 4 bolt to 5. again for more wheel options. I think wants the M3 Contours on it or even the M3 LTW wheels
(OO==[][]==OO)
Old 10-17-2007, 01:49 PM   #8
lol, no its not that easy.
The only slightly cheaper solution is to use a combination or z3 and e36 parts, but there are some caster issues up front with using e36 parts, appearently with the right parts you can get it within spec.....but you'd have to do your research.
Drilling the hubs is not a proper solution.
Many dont do it just for the wheels, many do it for the better oem brake options. e36 m3 fronts, m-coupe rears make for some powerful brakes.......providing you have the power to back it up.
But there are some nice oem wheels you can run.
If the primary reason for him doing it is for the wheels, then it would be cheaper for him to find another set that comes in 4x100.
Old 10-17-2007, 02:11 PM   #9
5JABIJ8
5JABIJ8's Avatar
Thx. I'll let him know and see what happens from there. thx to eveyone for their quick replies on this
(OO==[][]==OO)
Old 10-17-2007, 07:44 PM   #10
Whip_lash
Whip_lash's Avatar
18's would look wayy to big on an e30, it just wouldnt look right. Tell him keep the 4x100 setup as there are some nice wheels that come in that bolt pattern. Also tell him to keep an eye on vwvortex.com , the 4x100 wheel forum has alot of em for sale.
Whip_lash is offline   Reply With Quote
