Old 10-14-2007, 10:32 AM   #1
Lower_Level
No-Budget Enthusiast
Lower_Level's Avatar
hah! figure this one out!!
So maybe it's been like this ever since I owned the car; I dunno. It got put away way too early last year & I never had to use the heater/defrost before. But this last week it's been so fawking cold at night I haven't had a choice.
My car's got a manual dual climate control for starters. When the selector is put on vent, it blows cold air out of both sides when the knobs are set to 15 or whatever it is. On defrost, the driver's side blows screaming hot air regardless of settings; and my passenger side will blow hot air if the driver's side control is set to "hot" (18 +). The passenger control doesn't seem to do anything! It gets so hot in the car that I have to either switch back to vent to get some cold air, or have the passenger side on cold to try & blend the air; but that usually starts fogging up the inside of the windshield on the pass. side...
Is it possible that the douche that owned the car before me screwed something up when he installed the CD player & maybe unhooked something that he shouldn't have? Or is this maybe a more common problem with a simpler solution?
'95 325is - //M Body - Shark Injected - Sport Pkg - Depo's with HID's
Lower_Level is offline   Reply With Quote
Old 10-14-2007, 02:42 PM   #2
carjoe
carjoe's Avatar
Sounds an awful lot like my car and I'm pretty sure the heat valve is fooked.
Where's my cookie?
93 325is - sold!
2000 540ia- sold!
Old 10-14-2007, 02:47 PM   #3
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
middle vent on the dash above the radio:
you have dial below that vent: blue side (outside air) & a brown side (heatercore)
on all other vents the dial just open or closes the vent..
i have found that even at the lowest settings its just Hawt..
cars heater core works good too good!
