Old 10-09-2007, 07:21 PM   #1
SamE30e
SamE30e's Avatar
I sware to whatever!
I am going to drop kick my car. I started the process of removing the clutch. Lets just say 21 year old exhaust bolts are bitches!
Does anyone know how I should go about removing the exhaust from the manifold, or should I just remove the manifolds themselves, drop them down then undo the bolts?
85 325 - Turbo M52B28.
Old 10-09-2007, 07:33 PM   #2
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
if you cant get them inplace chances are you wont when its dropped down. just zip cut the head off the bolt and put new ones on. and or get new exhaust stuff cause if those are rusty, your exhaust is probably in need of fixing aswell...
86coupe30 is offline   Reply With Quote
Old 10-09-2007, 07:48 PM   #3
SamE30e
SamE30e's Avatar
It's fine, its just getting to them, I've got 3 of the 6. It's just a PITA and I know it's possible. The exhaust isn't rusty until it gets to the over the axle part because it has been replaced, so i'd prefer not to cut it or anything.
Old 10-09-2007, 07:50 PM   #4
86coupe30
1990 325is
86coupe30's Avatar
oh i see. good luck with it then
Old 10-09-2007, 07:56 PM   #5
klm325ix
BMW ROOKIE
Send a message via MSN to klm325ix
i removed my exhaust manifold. was lucky enough to remove it from the head. however, when i went to put it back the left flange cracked completely. had to get it welded. if you are careful, you could get away with removing the whole manifold and then taking it apart from the exhaust. good luck with it.
klm325ix is offline   Reply With Quote
Old 10-09-2007, 09:24 PM   #6
dgmorr
invest in a cheap oxy/acety torch, it'll make a 4 hour job turn to 20 minutes.
Old 10-09-2007, 09:36 PM   #7
BigD
the misanthropist
BigD's Avatar
Just in case you're following the Bentley to a tee and haven't done this before - REMOVE THE STARTER OR YOU WON'T BE ABLE TO GET THE TRANSMISSION OFF!!! I did my first E30 clutch in the underground of an apartment building with no light - took me 5 fuggen hours to figure this one out, and it's not in the instructions anywhere.
Old 10-09-2007, 10:49 PM   #8
SamE30e
SamE30e's Avatar
I'm using the bently in my head... haha
Old 10-09-2007, 11:29 PM   #9
Arash
Arash's Avatar
Put nevercease grease on everything when putting it back together! I just did a manifold job today, exhaust bolts are always a PITA
Arash is offline   Reply With Quote
Old 10-09-2007, 11:56 PM   #10
SamE30e
SamE30e's Avatar
I got them off, they came off fairly easy, it was just getting to them by myself. The head was rebuilt 2 years ago, so they wern't on there long. I got them off, the exhaust out, and heat sheilds off. Now how do you get the drive shaft off, I have it all unbolted from the transmission end and the centre support bearing off but the yoke won't pull down far enough to pull the half out.
Old 10-10-2007, 12:36 AM   #11
Trekz
what i did when i was swaping my engine with the tranny on, is loosen up engine mounts and tranny mounts and let the tranny hang down
Trekz is offline   Reply With Quote
Old 10-10-2007, 09:02 AM   #12
BigD
the misanthropist
BigD's Avatar
Yeah tilt the engine back as far as it'll go (jack it up by the front of the pan carefully), loosen the collar on the driveshaft, collapse it fully, and it'll pop right out. The transmission angle will allow you to have a bend in the driveshaft, which effectively shortens it a bit more, also letting you pull a bit down, not just back.
Old 10-10-2007, 09:32 AM   #13
e30_kid89
The Afro-stig
e30_kid89's Avatar
Maybe the exhuast is not an issue since its single pipe but if you lower your exhaust a bit it helps the driveshaft collapse as well.
Old 10-10-2007, 10:55 AM   #14
SamE30e
SamE30e's Avatar
The exhaust is off. so do I just undo the tranny subframe and drop it down?
Old 10-10-2007, 06:17 PM   #15
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
yup, just take the whole tranny mount cross member off.
Grow up and move on.
