Old 10-09-2007, 05:31 PM   #1
Nascar318is
Nascar318is's Avatar
DIY-How To Remove Tint
Well long story short I was nabbed on my way to Bav Auto. My front windows were too dark. So I had to go get it tested at a shop. I had 48 hours and then my plates would be suspended.
So today I took my tint off. It took about 40 minutes to do both sides glue and all.
Here's what you need.
Bought some Amonia and a window scraper at CT ($7 for both)
2 Razor blades for the window scraper, one already comes with it.
1st-Hot water and diswashing soap. Grab a rag and and spread it all over your windows. The heat will loosing the glue abit.
2nd-Window scraper- lift a corner of the tint and pull it all off in one shot.
3rd-I mixed 250ml of Amonia to 200ml of hot water.
4th-Spread the water and amonia all over your window(make sure you have something to wipe off the access on your door cards or anywhere else)
5th-Window Scraper I started from the bottom and worked my way up. This will take the glue off. (use one razor per side)
Once you are done, take a look from the outside of your window to see if you missed any glue, scrape the access off.
Just wash your windows with plain hot water and you are done.
Old 10-09-2007, 06:48 PM   #2
Wannabe
Northwood.
Wannabe's Avatar
good write up.. i might take all of mine off soon.. want a change of look
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
