Cooling issues.
I recently got this car. First thing on the list was to change the t-belt/water pump. That has been done.
The other problem that i had was it would never heat up to the proper operating temp. Where does your temp gauge needle stay at? Is it just below the middle mark? Mine was pass the blue, just a little over the first quarter mark.
Turned out viscous fan clutch was seized so the fan was on all the time. I got rid of the fan. Then i tested my auxilary fan and it only works on high speed setting. Low speed it doesn't work, although i hear the relay clicking. So i figured i need a new fan. I let the car idle till the needle on the temp gauge passed the middle and the high speed fan kicked like its suppose to. I test drove the car and the needle would drop down to that same point where it was before.
So my next step was the thermostat. And yes i put a chinese thermostat.
Don't ask me why i did it, it's done. It was a disaster to bleed the system, i had a huge air pocket. Anyhow, i managed to bleed it and decided to see if my high speed fan would kick in again. The fan didn't kick in and obviously coolant started to overfloat the reservoir bottle. I shut the engine off. Jumped the wires on the fan and it does work this way, when i connect it back it doesn't work through the thermo switch. It's weird cause the switch was just turning the fan on last night ( on the high speed).
I drove the car with no fan thinking since it has new thermostat it would be fine but the temp is still one quarter pass the blue mark.
Sorry for the long story, i searched and didn't see anyone having the same problems. You guys have any inputs on that?
Any help is appreciated.
Thanks.
