Old 10-07-2007, 10:09 AM   #1
rwdbmwm3
obdII scanner doesnt work on bmws?
what do people usually use for bimmers
Vagcom?
rwdbmwm3 is offline   Reply With Quote
Old 10-07-2007, 02:08 PM   #2
carjoe
carjoe's Avatar
Isn't your car a 95?
93 325is - sold!
2000 540ia- sold!
Old 10-07-2007, 04:04 PM   #3
PedroBMW
Hooked on Boost
PedroBMW's Avatar
obd2 scanners do work, as long as your car is obd2 (1996+), the thing is that some of the codes are hard to find out what they mean, if they're not in the book that comes with the tool. You can get the peake scan tool that will read everything for ya for an e36, turner sells it.
http://www.foldingtrailers.ca
Old 10-07-2007, 07:31 PM   #4
rwdbmwm3
i know what obd2 is ...my question was does it work because i hooked it up to mine and it gave me error so i just thought that it doesnt work with BMW's
Old 10-07-2007, 08:21 PM   #5
PedroBMW
Hooked on Boost
PedroBMW's Avatar
sorry brotha i wasn't questioning your intelligience or anything, it must be your scanner, mine works.
Old 10-07-2007, 11:27 PM   #6
rwdbmwm3
my scanner probably just a piece of shit lol
what kind do you have?
brand and model
worse comes to worse ill take it to my electrician and get him to scan it
Old 10-08-2007, 12:47 PM   #7
thinair
moderationistismingly
thinair's Avatar
There are a few different OBD-II standards.
SAE J1850 PWM - Ford
SAE J1850 VPW - GM
ISO 9141-2 - Chysler, European, Asian
The plug is the same between the standards
Old 10-25-2007, 02:19 AM   #8
328i Cab
I have had an issue trying to scan both my e36 cab when i had it and an e39. What i didn't realize is that you need to have the key on and the obd-II cover on (i think it actually shorts out two of the pins when it's on if i remember correctly) before you hook up the tool.
Try turning the key on, removing the cap and hooking up your tool and trying to scan. My POS tool would just give errors and I didn't figure out the relationship for a while but have had no issues with any obd-II bimmer i've scanned since.
Good luck!
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
