Old 09-29-2007, 01:30 AM   #1
Redster
Stuck In The 6th Gear
Redster's Avatar
Will it fit (rims)?
Is there any way 16" rims would fit on a 2004 330i? I asked a guy who has them for sale and he said they were on 04 330ci and because if the design they fit fine.
Another question, 04 330ci and 04 330i M package, would they both have same rotors (size)?
"You wanna make moves on the streets? Do not have any attachments, do not have anything in your life you are not willing to walk out on in 30 seconds flat if you spot the heat around the corner."
Redster is offline   Reply With Quote
Old 09-29-2007, 02:20 AM   #2
Soldo
Soldo's Avatar
330's had the same size rotors if it was an M package or not. As for the rims fitting, i dunno. I remember some people said that with E36's SOME 16" rims would fit on M brakes, but the 330's have a bigger disc than the E36 M brakes, so i'd be skeptical on that!
Keven Soldo
Old 09-29-2007, 02:33 AM   #3
Redster
Redster's Avatar
Yes but those rims fit on 04 330ci so then they should fit on 04 330i w/ m package..?
Old 09-29-2007, 10:53 AM   #4
The M Sport model has the same brakes, yes.
As I posted in one of your WTB threads a month ago, 99% of the 16s don't fit. Obviously, this means 1% do.
Old 09-29-2007, 01:30 PM   #5
^^yep.
i've seen 16 inch steelies on a e36 M, as well as actually a great looking pair of 16 inch contours.
most 16 inch rims that clear brakes are designed especially for BMW, so that people dont have to spend money on 17's. I used to think bmw had a set of oem 16's that would fit, but have since been proved wrong, apparently they're all aftermarket.
Old 10-03-2007, 07:06 PM   #6
ZHP_Bimmer05
Photographer/DJ/Engineer
Send a message via MSN to ZHP_Bimmer05
actually, my brake rotors look bigger than regular 330's, i measured it
2004 Mazda RX8 GT: 6spd VR
ZHP_Bimmer05 is offline   Reply With Quote
Old 10-03-2007, 07:19 PM   #7
Blades
Your opinion is to long
Blades's Avatar
will not fit .. you need 17" + .. you might even run into some problems with certain 17's
-=[ BL/\DES ]=-
Old 10-04-2007, 05:25 PM   #8
Get a new measuring tape.
http://bmwfans.info/part-34101166071/
Same rotors in every single 330 model (including even diesels and awd).
Old 10-04-2007, 05:33 PM   #9
Wrong.
The pics aren't working anymore, but here's one of many 330 guys running 16" wheels: http://www.bimmerfest.com/forums/showthread.php?t=47373
Like I said, you just need specific models.
Old 10-04-2007, 09:26 PM   #10
shimajer
loudddddd
some 16"s fit.. but only a small number of them because of their interior rim design..
but i would get 17s just becausee... you can sell them easier later on?
Old 10-04-2007, 10:03 PM   #11
ZHP_Bimmer05
maybe it was a 325i, my bad
Old 10-04-2007, 10:11 PM   #12
330ci05
330ci05's Avatar
Wrong.
lol, u got answer for EVERYTHING,,,,and links to back it up hehehe...
330ci05 is offline   Reply With Quote
