Old 09-26-2007, 08:53 PM   #1
ecuconnection
ecuconnection's Avatar
rim & spacer advice
FOR SALE !!!! BMW 18 spoke set of 4 6.5 x 14inch rims / 5x120mm bolt patern sporting dunlop 195/65/14 tires with 50% tread left.... orginaly off a 88' 528e $125.00 for the set
MUST GO ASAP!!
Old 09-27-2007, 09:30 PM   #2
ecuconnection
Bump!! 100$
Old 09-28-2007, 01:16 AM   #3
Hey Bear, why is the title rim & offset advice?
Old 09-28-2007, 07:27 AM   #4
ecuconnection
I was orginaly asking how I would make them fit on my car but then I said screw it to much work anyway you want em ?? $80 if you take em befor next weeknd
Old 09-28-2007, 10:58 AM   #5
I've already got 15" steelies with winter and 17" BBS RX with brand new winters, so if I got more wheels I would have to build a level in the garage.
Did you try these? I think all you'll need is rings. They're so narrow the additional offset will likely fit ok.. ?
Old 09-28-2007, 11:01 AM   #6
IIRC, these rims are 72.1mm bore and your care is 72.5mm. You could literally build up the .4mm difference with aluminum tape and they'd probably work just fine.
Old 09-29-2007, 09:55 AM   #7
ecuconnection
Bump 80$
Old 09-29-2007, 07:05 PM   #8
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
or 1010tires.com (canadian co) & get some plastic ones in any size pretty much??
Old 09-29-2007, 08:47 PM   #9
jeffrie
Addict
jeffrie's Avatar
14" do not clear his breaks, poor bear couldn't use them even with spacers.
Old 09-30-2007, 12:29 AM   #10
ecuconnection
somebody must be able to use there I will take 60$ for them befor bav
Old 09-30-2007, 04:56 PM   #11
bmdbley'sBro
^I dunno... most 5x120's had 15"s except for e30, m3's ???
what did these come from?
Old 09-30-2007, 06:33 PM   #12
ecuconnection
off a 88 528e or sometihng
Old 09-30-2007, 07:38 PM   #13
The rims will fit any 5, 6 or 7 series except for the e39. Newer cars should be test fitted for clearance of the brakes.
The e39 hub size is different. Its like the red-headed step-child of the BMW clan. (chromius BURNED!) j/k
Old 10-01-2007, 09:25 AM   #14
chromius
chromius's Avatar
