Old 09-21-2007, 09:08 PM   #1
Zorin
Herr Meister
Zorin's Avatar
Fusebox removal
Fusebox removal - do I need to remove entire harness from the car or is there a simpler way ?
Zorin is offline   Reply With Quote
Old 09-21-2007, 11:16 PM   #2
Magic_Black
BMW ID Designer
Magic_Black's Avatar
Wny do you need to remove the fusebox, just curious.
I have done a fusebox swap, and its not an easy task.
Magic_Black is offline   Reply With Quote
Old 09-21-2007, 11:52 PM   #3
Zorin
Herr Meister
Zorin's Avatar
I am rebuilding entire car and I need to remove some rust behind the fuse box.
I have decided to relocate the fuse box to the inside of the car rather than to disconnect the entire wiring.
Old 09-22-2007, 08:27 PM   #4
Zorin
Herr Meister
Zorin's Avatar
Done - no help needed anymore.
Old 09-22-2007, 10:43 PM   #5
FuryriderX
cra.iX.y
FuryriderX's Avatar
got a picture of this? it sounds pretty neat - where did you end up putting it?
Old 09-22-2007, 11:54 PM   #6
Zorin
Herr Meister
Zorin's Avatar
I will take photos tomorrow - I basically pulled entire wiring from the car without disconnecting it so that way I can mount the fuse box inside the car and rewire what needs to be rewired. I am a long way from being completed on my 318i.
Here is before the wires were removed.
