Old 09-18-2007, 11:24 PM   #1
Zorin
Herr Meister
Zorin's Avatar
M10 fuel injector upgrade
Hi,
I am currently working on 1.8 M10 with stock injectors. I am considering an upgrade. Which injectors from other BMWs would be worth using without problems ?
Thanks,
Zorin is offline   Reply With Quote
Old 09-19-2007, 03:38 PM   #2
2002guy
Send a message via MSN to 2002guy
go with and e36 318 ti injection system ill see if i can find the link again it has been done on a 2002..
Sposered by: M-Tricks Autosports
My Cars:
1974 "2502" m20 2002
1989 735i
1982 vw rabbit
2002guy is offline   Reply With Quote
Old 09-20-2007, 03:39 PM   #3
Zorin
Herr Meister
Zorin's Avatar
I was told by an import mechanic that I can use any injectors from any car (as long as they fit ofcourse) with engine size 1.8 to 2.2/2.4.
What other upgrades to M10 make sense - other than going turbo ?
Old 09-20-2007, 07:32 PM   #4
2002guy
to me not really anything since you are building an e30 i would just go with an m30 setup or a s52.. but if you wanna keep the four banger go with the s14.. it will bolt up right to and m10 engine mounts with no mods needed. you can use any tranny thats bolted up to an m10 or go with the s14 tranny but dont know if you have to modify the tunnel to fit it. but the biggest problem would be mating both harnesses together
My Cars:
1989 735i
1982 vw rabbit
Old 09-20-2007, 07:56 PM   #5
Zorin
Herr Meister
Zorin's Avatar
I don't really want to change the engine as for some reason I like the simplicity of M10. I upgraded the coil and sparkplug wires and I will upgrade the injectors. I guess I will see once it is back on the road. I am also thinking on having custom header made and of course better exhaust.
Old 09-20-2007, 09:49 PM   #6
2002guy
you dont need custom check out ireland enginering www.bmw2002.com they might have them...and for exhaust dont go bigger than 2.25 inches cause then your loosing a lot of power...2 inch is perfect for a street apllication
My Cars:
1989 735i
1982 vw rabbit
Old 09-24-2007, 09:06 AM   #7
Zorin
Herr Meister
Zorin's Avatar
Thanks, but it will be cheaper to do header locally.
They have really nice stuff for older BMWs.
Old 09-24-2007, 07:20 PM   #8
2002guy
i paid just over $300 us for a reground cam and headers from IE that was with shipping i dont know if its cheaper to get them made
My Cars:
1989 735i
1982 vw rabbit
Old 06-12-2008, 03:43 PM   #9
Zorin
Herr Meister
Zorin's Avatar
Originally Posted by weiwei View Post
这是新加的空白文章1,可以在UBB可视化编辑器中,添加和修改文章内容。
wow, I never thought about that one - thanks !
1984 318i w/M10 - restomod in progress :-)
1984 325e - in car heaven now :-(
1991 325i - project / parts car
2005 325i executive edition - daily driver :-)
http://www.cardomain.com/ride/2831989
Old 06-14-2008, 01:56 PM   #10
^^ IIRC any injectors will work, as long as its the same impedence as the stock ones... Look around on e30tech, there may be some more info on that there because there are a few people into Turboing those on that board, and they should be able to tell you whats up.
