Old 09-13-2007, 08:20 PM   #1
Zorin
Herr Meister
Zorin's Avatar
Rust Remover
Hi,
I am currently resto-modding 318i and I am looking for a good rust remover in liquid or gel form. Any suggestions other than your standard HD, Canadian Tire, Parts Source products ?
Thanks,
Zorin is offline   Reply With Quote
Old 09-13-2007, 09:02 PM   #2
2002guy
Send a message via MSN to 2002guy
replace the sheet metal nothing works better
Sposered by: M-Tricks Autosports
My Cars:
1974 "2502" m20 2002
1989 735i
1982 vw rabbit
2002guy is offline   Reply With Quote
Old 09-13-2007, 09:08 PM   #3
Zorin
Herr Meister
Zorin's Avatar
I am aware of that :-) and I have done that as well.
I need it more for spot removal and general cleaning.
Old 09-18-2007, 08:55 PM   #4
2002guy
the grind it down to bare metal but go an inch or so wider and just do a realy good clean up of the general area and dont cheap out on primer and paint use good stuff
My Cars:
1989 735i
1982 vw rabbit
Old 09-18-2007, 09:22 PM   #5
Zorin
Herr Meister
Zorin's Avatar
Again, thank you and I am aware of how to cut out rusted area.
As to primer, I am using Tremclad Primer. My question is more about a chemical that can be used in tight places with small surface or sport rust.
Old 09-18-2007, 11:11 PM   #6
FuryriderX
cra.iX.y
FuryriderX's Avatar
the rust check stuff in the green can works pretty good for stuff like that, plus it stays put and gooey afterwards. (doesnt trap water underneath)
i know its a CT product, but its seemed to work good for me
Old 09-18-2007, 11:58 PM   #7
Marky_mark
Detailing Specialist
Marky_mark's Avatar
You can also go to a uap napa store that sells auto body supplies and get it from there that would be your best bet to get a really good rust remover
Good luck with our resto-modding
Old 09-19-2007, 12:06 AM   #8
Since you know all that, why are you asking!? Go to any body shop and see if they use anything else then cut/grind/sandblast/acid bath methods...Anthing else is pointless, the cancer will always come back...
For your project a small sandblaster will do the job...
Old 09-20-2007, 04:01 PM   #9
Zorin
Herr Meister
Zorin's Avatar
Yes, I know that and my question was not about cutting out rust but about rust remover. I was asking more to hear what other people used in a way of chemical removal of surface rust or rust in hard to get spaces. Thank you for input.
