Old 09-12-2007, 08:17 PM   #1
Redster
Stuck In The 6th Gear
Redster's Avatar
Electrical question
So I got my Depo headlights installed, and then I installed ThinLine Angel Eyes. Today I cut the wire for the side lights (same bulb as turn signals) because it just looks bad (IMO) when that's on with the xenons/angel eyes.
OBC is displaying the message now (Check side lights) so is there a way to erase that, or should I just connect angel eyes there so the computer will still read that the lights are working?
"You wanna make moves on the streets? Do not have any attachments, do not have anything in your life you are not willing to walk out on in 30 seconds flat if you spot the heat around the corner."
Redster is offline   Reply With Quote
Old 09-13-2007, 01:24 AM   #2
BMW03
woah, I'm not sure. I would think there is some way to get he OBC to ignore that though. Hummm.
BMW03 is offline   Reply With Quote
Old 09-13-2007, 09:53 AM   #3
BMW03
anybody......... I'm curious to the answer.
Old 09-13-2007, 09:57 AM   #4
Redster
Redster's Avatar
I'll try over the weekend, but I'm 99% sure that if that same wire is connected to something else that needs 12V (inverter in my case) the OBC message should go away.
Old 09-13-2007, 11:43 AM   #5
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
It needs to have an appropriate resistor. An inverter will fry the fuse, as it draws far more current than the bulb it replaces. Basically measure the resistance of the bulb, and solder in a replacement resistor, and you're kosher.
Old 09-13-2007, 12:05 PM   #6
BMW03
there we go that sounds like a good idea, because there would be a good chance of blowing it if it is the wrong resistor. Good luck, respond with outcome.
Old 09-18-2007, 09:27 AM   #7
BMW03
hey what did you find out?
Old 09-24-2007, 04:59 PM   #8
Redster
Redster's Avatar
I finally did this today, and connecting that wire to the inverter for angel eyes is all you need to do so OBC stops displaying the message to check side lights.
I guess the main computer just wants to see something using power, because the inverters put out over 500V so I'm sure they use MUCH more power than the side light bulbs.
Old 09-25-2007, 09:13 AM   #9
BMW03
humm interesting, but nice work.
Old 09-25-2007, 12:56 PM   #10
Redster
Redster's Avatar
Works like a charm, no more OBC error messages.
