Old 08-31-2007, 10:52 AM   #1
automadness
cross drilled or slotted rotors
i have an 2001 330 and i put on cross drilled rotors because the stock ones got warped at about 40000km now the new cross drilled are warped after 5000kms and less then a yr of drinving can anyone recommend good rotors to put on or does anyone else have this problem
automadness is offline   Reply With Quote
Old 08-31-2007, 11:04 AM   #2
Boots R
Boots, not boost
Boots R's Avatar
How hard are you driving?
Old 08-31-2007, 11:14 AM   #3
automadness
i dont drive it that hard and if i do drive hard i dont really brake that hard.. also is there a certain way to break in the new breaks? i heard about that once
Old 08-31-2007, 11:37 AM   #4
King Luis
The King.
King Luis's Avatar
when ever you get new rotors you need to heat treat them or they can warp easily. i forget the exact procedure but it consists of not letting the car come to a complete stop and not dragging the brakes and doing it repeatedly. then letting the brakes cool for 15+ minutes.
your brakes were probably warping because; A. you were braking and turning hard or often. or B. you didn't break in your brakes when you first got them.
a good set of pads and solid rotors should do you fine.
remember. your brakes are only as good as your tires.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 08-31-2007, 12:05 PM   #5
automadness
does anyone know exactly how to work in the rotors? also is it true that brembo is making 330 rotors now thats what they told me at canadian tire?
Old 08-31-2007, 12:42 PM   #6
325isRED
325isRED's Avatar
I would go blank rotors. Or a nice BBK
'92 325is 5sp
Old 08-31-2007, 01:52 PM   #7
King Luis
The King.
King Luis's Avatar
google how to break-in the rotors.
from what people tell me, it sounds like brembo is the only brake rotor company in the world. so i'd don't think the crappy tire guy is right.
Mods: TBD.
Old 09-01-2007, 12:51 AM   #8
Romaz
Romaz's Avatar
RMP told me that the only crossdrilled rotors available for the 330 are Zimmermans
Romaz is offline   Reply With Quote
Old 09-01-2007, 01:18 AM   #9
Sneaky
One of the Zealots
Sneaky's Avatar
Brembos, or Stock. No inbetween
THE OFFICIAL BLACK SEDAN THREAD because Nothing breaks necks like a Black BMW.
Sneaky is offline   Reply With Quote
Old 09-01-2007, 10:32 AM   #10
LADY_SAUBER
ENTHUSIAST IN TRAINING :)
LADY_SAUBER's Avatar
LADY_SAUBER is offline   Reply With Quote
Old 09-01-2007, 03:12 PM   #11
automadness
well thats what i got on the car now the Zimmermans with the ECB pads from RMP and they are warp already after only 5000kms. brembo didnt make rotors for the 330 they had them for the 325 when i got mine
Old 09-01-2007, 03:21 PM   #12
e46silver
2003 325i TiAg
e46silver's Avatar
They should still be under warranty, aren't they? After 5000kms and the rotors warp?? Talk to Rocco and see what he can do for you.
e46silver is offline   Reply With Quote
Old 09-01-2007, 06:24 PM   #13
Karim@Corner73
Karim@Corner73's Avatar
Brembo makes good quality rotors but they seem to be more prone to warping.
We sell a lot of Zimmerman rotors for the 330 and we've never had any complaint. Zimmerman makes plain or cross-drilled rotors.
For normal street-use, I would stick with plain rotors.
Warping a rotor is not that common. Are you sure your rotors are warped? A lot of different things can cause a pulsating brake pedal and/or a shaky steering wheel.
Read this if you want to know more: http://www.stoptech.com/tech_info/wp...rakedisk.shtml. It's very interesting.
The most common problem is pad material deposits on the rotor surface. A dented or unbalanced wheel can also give symptoms similar to warped rotors.
Before replacing your rotors once again, make sure that they are warped.
Karim.
