Old 10-26-2006, 02:26 PM   #1
The Sly
The Sly's Avatar
Supercharged E30
Finally done
I have been able to supercharge my e30 with a M62 Eaton supercharger.
I was able to bring it up to 13lbs at first try but now it is up to 7 lbs.
Since i have a high compression 2.7i, detonation is right around the corner so i have ordered a thick multilayer head gasket with arp head studs.
Here are a few pictures of the setup :
Alternator is on the other side
It all started on my mock-up engine
The Sly is offline   Reply With Quote
Old 10-26-2006, 06:36 PM   #2
paul christians
87325is///MR.EVIL
^^^that is sooo cool SLY....
87is325///2.7L..EVIL.....
Old 10-26-2006, 08:14 PM   #3
Bob Loblaw
Zee Frog.
Bob Loblaw's Avatar
Time to start a rear tire fund, eh!
Bob Loblaw is offline   Reply With Quote
Old 10-31-2006, 11:49 PM   #4
dgmorr
Doesn't the 2.7i have very low compression? 8.5ish:1?
dgmorr is offline   Reply With Quote
Old 11-01-2006, 05:13 PM   #5
The Sly
The Sly's Avatar
Most of the guys uses the Super ETA setup but in this case it is not..
I have presently 10 to 1 compression
Old 11-01-2006, 07:49 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
What kind of power are you making?
Old 11-01-2006, 08:11 PM   #7
The Sly
The Sly's Avatar
AS of now none... cause i took the head off the car to put in a thicker head gasket so i can raise the boooost and also put in a fuel management system and timing control unit.....
When i first tried it ...Lets say first gear is worthless and 2nd gear is almost wortless since i spin all the way on both gears and 3rd spins but then i start to have traction so i need to change the Diff sooon and this was at 7 pounds but i want to go as high as i can...
Sly
Old 11-01-2006, 08:34 PM   #8
Axxe
Axxe's Avatar
Cool. Sound like fun, no intercooler tho I take it?
Old 11-01-2006, 08:54 PM   #9
SpoolinS6
SpoolinS6's Avatar
what did the charger run you price wise im just curious ?
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 11-02-2006, 12:00 AM   #10
jeffrie
Addict
jeffrie's Avatar
Doesn't look new, what did that come off of? I'd geuss a 3.8l GM but theirs no long shaft extension from the pully to the charger..
Old 11-02-2006, 01:13 AM   #11
Hey Sly, I've got a 2.93LSD coming out of my parts car you can have for next to thing if you need it. Pm me.
Old 11-02-2006, 01:15 AM   #12
Oh, and awesome. If this works out, you may have a customer. I originally wanted to s/c and was convinced to go turbo because of the knowledge base. My e30 has no power steering and the overflow tank can move, leaving the whole left side of the motor if that helps..
Seriously, I'm interested.
Old 11-02-2006, 01:40 AM   #13
Axxe
Axxe's Avatar
Looks like a merc unit.
Old 11-02-2006, 12:56 PM   #14
chromius
chromius's Avatar
Wow, Awesome project Sly.
I also have a 2.93 LSD sitting on the garage floor if you don't end up getting Jay's
Old 11-02-2006, 01:22 PM   #15
Nascar318is
Nascar318is's Avatar
Congrats Sylvain, I knew it wouldn't take long after you sold your other E30. Luskville next year? You, Lee, Jay, Adam 318is....should be fun
