Old 08-21-2007, 10:58 AM   #1
Bandi
der mechanik
Bandi's Avatar
Send a message via MSN to Bandi
'84 318i losing injector pulse
Hey everyone... I'm working on an '84 318i that belongs to my friend, the car *usually* runs great, but now it's not revving past 1200 rpm. (It used to do this intermittently, usually if you hit a bump). Timing is okay, and I tried changing the pickup coil in the distributor.
Anyhow, I've determined that when you try to rev the car higher, it's losing injector pulse. Any suggestions? Where does the car get the injector pulse signal from? (I have a few service manuals... just not here at work.)
Any help would be greatly appreciated.
-'72 2002
-'72 Super Beetle
-'72 Baja Champion SE Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'65 Fiat 1500 Cabriolet
-'99 New Beetle TDi
-'84 Rabbit Cabriolet SportLine
-'91 Tercel GT-S Twin Cam
Bandi is offline   Reply With Quote
Old 08-21-2007, 11:14 AM   #2
It gets it from the ECU, it could be either a broken wire somewhere causing a faulty connection which would be a bitch to find, or if your lucky, its the ECU. Do you have a spare you can try swapping?
Old 08-21-2007, 11:55 AM   #3
Bandi
der mechanik
Bandi's Avatar
Thanks for the response.
Don't have a spare ECU (I'd have about 20 if this was a 6 cylinder car)
Any idea where the ECU gets the rpm reading from? I have a super basic diagram here that's showing the coil negative terminal, but it doesn't show which terminal it gets fed to the ECU thru.
Or, is it using the pickup coil in the distributor for something?
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
Old 08-21-2007, 12:21 PM   #4
Sorry I don't know M10s enough, I'd have to see a wiring diagram to try and figure it out.
Old 08-21-2007, 07:52 PM   #5
e30jones
I have two spare 310 L-jet ECU's if you want to try them out...I don't have an 84 anymore, so they are available for sale if you need them too...
Check this site out for Electrical Troubleshooting Manuals, there is the Injection Control Module above the glove box too...might have something to do with this, I think its a smaller green box?
Here--->> http://wedophones.com/BMWManualsLead.htm
e30jones is offline   Reply With Quote
Old 08-22-2007, 07:13 AM   #6
Bandi
der mechanik
Bandi's Avatar
I think the car was just given to me... so next question... M20 swap?
Thanks for your help guys.
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
Old 08-22-2007, 07:48 AM   #7
if the car has no rust, do it.
Old 08-22-2007, 09:41 PM   #8
Bandi
der mechanik
Bandi's Avatar
It's really solid (And pretty nice looking, the car is sort of a tan colour with dark brown leather) , and I have a wrecked '87 325i in the barn that would make a perfect donor car.
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
Old 08-25-2007, 09:17 PM   #9
LADY_SAUBER
ENTHUSIAST IN TRAINING :)
LADY_SAUBER's Avatar
^agreed
it's kinda difficult to diagnose intermittant situations... but maybe u can start by confirming the injector's electrical integrity. perhaps test the resistance of each injector with a noid light? This will prove it's communication with the ECU is in effect. Because remember, resistance will change according to the injector's temperature a.k.a bad ground a.k.a low injector pulse width
LADY_SAUBER is offline   Reply With Quote
Old 08-26-2007, 11:32 PM   #10
Bandi
der mechanik
Bandi's Avatar
Yup, I've checked injector resistance, pulse with a noid light (that's how I determined the injector pulse goes away when the car hits 1500 rpm)
As for broken wire, I've tested the ENTIRE efi harness for continuity/voltage drops/etc... as well as RPM signal everwhere it should be.
The problem usually starts when the car hits a fairly noticeable bump (ie, train tracks)... but I have gone through the entire harness, wiggled it around, bashed every component around with a screwdriver handle/etc (to simulate the shock), and can't get it to act up. (Or, if the car is acting up, I can't get it to correct itself)
Anyhow, I have this M20 sitting here collection dust... so I think that's the answer to my problem at this point... I'm kinda partial to the 6 cyl. E30s anyhow (I sold my 325is this past spring, and have missed it every day since)
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
