Old 08-02-2007, 01:09 PM   #1
lotus49
I need a bigger garage.
a bit of paint advice needed
Hi all - I've had my '89 325i for a couple of years. It's not concours but it's essentially rust-free. I'd like to take care of something I've been ignoring on the passenger-side B-pillar - see pic - it had these chips when I bought it and they're starting to get very unpretty. It' s the only place where it's like that. I think the rust is just starting to become more than surface.
Can anyone give me a Reader's Digest tutorial on how to fix this? I'm no bodywork wiz but I'm quite capable.
Thanks!
lotus49 is offline   Reply With Quote
Old 08-03-2007, 07:37 PM   #2
jamison67
E30 POWER
jamison67's Avatar
that just surface rust any body shop should be able to fix that for you for 50 to 100 doolors
jamison67 is offline   Reply With Quote
Old 08-03-2007, 08:33 PM   #3
SamE30e
SamE30e's Avatar
Just get a grinder and then flat black spray paint.
85 325 - Turbo M52B28.
Old 08-04-2007, 11:12 AM   #4
jamison67
E30 POWER
jamison67's Avatar
dont grind it you will see the grind marks sand it with 80 then work your way up to 120 then 180 ,240,then 400 then buy a can of sel etching primer because you will be down to bare metal and paint will not stick to bare metal , so you spray that on 2 light coats ,let it flash for about 10 min the spray it with a flat black ,bout 3 coats,ur first 2 sould be light coat just to get coverae then ur 3rd and last should be a med wet coat for a nice even low look ,and then ur done and it should last another 10 years
Old 08-04-2007, 10:19 PM   #5
Wannabe
Northwood.
Wannabe's Avatar
then be prepared to do the rest of them, because once you paint one, then it will stand out like a slut
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
Old 08-05-2007, 04:58 AM   #6
HoldenC
Pro Mobile Detailing
No easy fix, I'm afraid. It's just not a DIY. If you really, really can't afford to take it to a bodyshop and pay the 100-200 bucks to get it fixed right, I'll give you some tips. Just send me a PM and I'll reply on the thread.
If you take the DIY route, I can almost guarantee it won't look pretty.
Also, mods please move this thread to the detailing section.
HoldenC is offline   Reply With Quote
Old 08-05-2007, 11:26 AM   #7
If you do DIY, use Bumper Trim Matte black, not flat black. Just paint the one beside it as well and you likely won't see any difference. You won't need to prep the other as much, just remove all wax, lightly scuff so the paint sticks and paint.
DIY, and if it looks like total ass then pay for a shop to do it. I know I could DIY myself no prob and make it look good.
Old 08-05-2007, 02:37 PM   #8
HoldenC
This is not a DIY project.
Old 08-05-2007, 05:10 PM   #9
I don't think you should be the one to determine that.
Old 08-05-2007, 05:42 PM   #10
NickP
NickP's Avatar
Actually that piece looks like its on the door - the piece is relatively simple to remove and replace. I've never seen one rusted - you should have good luck in finding a mint piece in a junk yard.
If I remember correctly - if you first remove the lower outer trim on the door you can then pry it slightly towards the rear of the car on the bottom of the trim before pulling it down from under the upper trim piece. Practice in the junk yard and you should find it quite simple.
Old 08-06-2007, 05:15 AM   #11
lotus49
I was going to ask about just that, but I thought the thread was dead. Someone's selling the exact piece on eBay so I figured it can't be too hard to remove (perhaps harder to replace though!) It does in fact look like the chrome piece at the base of the window has to come off (or at least partly) to make way for removing it. If I can get it off I'm sure I can re-finish it. Plus it seems to me that some combination of grinding compound / Back to Black / and Armourall should help to getting the adjacent one to match.
But there's a detailing forum? I didn't know. I should go there, what?
Old 08-06-2007, 11:03 AM   #12
Can you post a link to the ebay auction (no I won't bid)?
Old 08-06-2007, 12:55 PM   #13
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
you should try to could try to color match it but it would be a bit tougher.. but if done right would look amazing.. people with vw sciroccos take the black out from inbetween the windows and it looks soo good. so im guessing it would do the same on this
86coupe30 is offline   Reply With Quote
Old 08-06-2007, 11:58 PM   #14
Hmmmm.. color match.. interesting idea.
Old 08-07-2007, 09:54 AM   #15
lotus49
Just go to the auto section and search "e30 b-pillar". The guy's parting out several cars in Indianapolis.
