Old 08-02-2007, 12:13 AM   #1
tig
tig's Avatar
amp started smoking but still works
ok this is really wierd i just got a new sub i wired it up, and as i was driving smoke started cominning out of the trunk pulled over opened the trunk and there as a lottt of smoke comming out of the amp, it was clearly comming from inside the amp i can see this because i have an MA audio amp and the cover has little holes all over it, i know sometimes smoke comes when the power wire touches another wire, put i am positive this wasnt the case, it was comming out of the amp for sure. So i thought ok amp is done i m screwed, the weird thing was started the car up and the amp worked just fine. Anyone know what this could have been? I know paul is one of the most knowledgeable guys on this forum when it comes to systems hes helped me out with some of my questions before, any idea what this might have been from paul or anyone else?
tig is offline   Reply With Quote
Old 08-02-2007, 06:54 AM   #2
UltimateDriv
Bimmerhead
UltimateDriv's Avatar
Send a message via AIM to UltimateDriv Send a message via Yahoo to UltimateDriv
maybe water damage.....
UltimateDriv is offline   Reply With Quote
Old 08-02-2007, 11:03 AM   #3
Impedance too low for the amp. Check your sub and amp specs as well as wiring layout (if sub is DVC).
Old 08-02-2007, 04:04 PM   #4
tig
tig's Avatar
is the amp still ok tho thats what i m worried about, it still works but i m scared something blew in the amp that gonna effect in in the long run
Old 08-03-2007, 11:57 PM   #5
djeurofest1
don't buy MA garbage inn the first place
djeurofest1 is offline   Reply With Quote
Old 08-24-2007, 07:31 AM   #6
Lower_Level
No-Budget Enthusiast
Lower_Level's Avatar
electronics & smoke are never a good combination. There's most likely a resistor that is now a puddle of plastic inside your amp. You'll probably notice problems when you start to really work the amp.
'95 325is - //M Body - Shark Injected - Sport Pkg - Depo's with HID's
Lower_Level is offline   Reply With Quote
Old 09-12-2007, 01:17 PM   #7
Nascar318is
Nascar318is's Avatar
Ditto..
do you blow alot of fuses? That's what happened to my old one, running it way to hot, blew fuses left and right and then one day poof smoke. Never worked again. That amp is gone now..
Old 09-14-2007, 09:00 AM   #8
tominizer
That's magic smoke................ and magic smoke is the amps way of talking to you and telling you it's gonna be $$$$ time soon.
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
