Old 07-25-2007, 03:24 PM   #1
atm2000
hood won't pop up.....!!@!@##$@
dammit.
is there a back door to opening the hood?
atm2000 is offline   Reply With Quote
Old 07-25-2007, 03:26 PM   #2
You dont want to know! Unlike the E30, you cant! Gotta cut things open...
Old 07-25-2007, 03:30 PM   #3
atm2000
WTF???? there has to be some kind of back door method to get that thing open.
Old 07-25-2007, 03:43 PM   #4
Boots R
Boots, not boost
Boots R's Avatar
punch your kidney grille out, and try manually pulling on the release cable.
Old 07-25-2007, 03:48 PM   #5
Nope! Tryed it, does not work, its very stupid but thats how it is....
Old 07-25-2007, 04:14 PM   #6
If you remove the kidney grilles, and cut the plastic peice you can gain access to the wire. Its a real bitch.
Did the cable snap?
Old 07-25-2007, 05:54 PM   #7
atm2000
the last time i opened the hood, it was for an oil change, about a month ago. other then that, the hood hasn't been popped.
has anyone heard of holding the hood lever and popping the release at the same time to open the hood?
Old 07-26-2007, 01:55 PM   #8
E36White
yaa thats how i ended up poppin my hood when i first got the car...u need 2 people for this procedure one to hold the lever and one to lift the hood at the same time..if it doesnt work: close the hood by pushing it down, bring the lever back to original position then try the steps mentioned above again.
update us
E36White is offline   Reply With Quote
Old 07-26-2007, 02:24 PM   #9
atm2000
update us
hey - it worked. i got my wife to hold the lever and I pressed the latch. the hood went up no problem. however, now the hood doesn't stay up...
not so much of a problem... is this a sign that something is going to go wrong soon with the cable hood?
Old 07-26-2007, 04:07 PM   #10
If the hood doesn't stay up, you need hood shocks. Call fil at eurostyle, i'm sure he has some (cheap) used ones for ya!
Old 07-26-2007, 04:38 PM   #11
E36White
ya u probably need hood shock(s)...the passenger one on mine was gone..
Old 07-27-2007, 11:06 PM   #12
soon2b-e
for your hood latch problem, do yourself a favour and call up the stealership, you'll wanna replace both latches (32 each) the middle cable (22) and the main cable (34 i think) those were straight from the bmw stealership (which i thought wasnt too bad) dont wait too long, because if you do you'll have a hellova time like i did, luckily i was working at "the" shop at the time
1995 325i- slushbox, cause i like it that way...
Soon2B- ??? - manual/stick cause i like it that way ?
soon2b-e is offline   Reply With Quote
