Old 07-23-2007, 09:30 PM   #1
mpereira
Left Brake Light Has No Power????
iVE GOT NO POWER COMING TO MY LEFT BRAKE LIGHT.. THE RIGHT HAS POWER,, ANYONE NO WHY SO?? IVE CHECKED THE FUSE AND IT GOOD. HAVE NO CLUE HELPPPP
mpereira is offline   Reply With Quote
Old 07-25-2007, 01:37 PM   #2
Nascar318is
Nascar318is's Avatar
Test light first to see if the bulb holder is actually getting power and go from there.
Make sure you check the actual bulb holder to see if it's not corroded, take it off the back of the light and lightly sand the connections inside the bulb holder. Take the bulb out and make sure the filements(sp?) are still intact, if not you need a bulb.
See if you can get ahold of another light and see if it lights up. If it does then you know you need a new light. Cause the board might be fubarred.
