Old 07-22-2007, 09:44 PM   #1
SamE30e
SamE30e's Avatar
Tach not working
Hey,
So I just bought my first BMW, 1987 325e and I don't know much about it. The one problem with it is, the tach and temp gauge doesn't work. After doing some research I found out it may be the battery in the SI board. Now I don't know 100% if that is it because when I start the car the check light flashes and then when I press the check button it turns off, I don't know if the SI board is working because this would lead me to believe that it would be working if this is...
Any help would be appritiated.
Thanks,
Sam
85 325 - Turbo M52B28.
Old 07-22-2007, 10:43 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
did you try slapping the dash with your palm? that sometimes works, haha
but seriously, that check light doesnt have much to do with the SI board, its a separate circuit. the ones the SI board controls are the green/yellow/red LEDs and the 'oilservice' light. its very easy to pull the cluster and take it apart to see if the batteries are leaking all over the place. if you need help with it pm me. i had to do the exact same with my car.
Old 07-22-2007, 10:48 PM   #3
SamE30e
SamE30e's Avatar
So the tach and temp gauge are controlled by the SI board?
So if I take it apart and see the batteries pissing everywhere what do I do?
Old 07-23-2007, 12:37 AM   #4
FuryriderX
cra.iX.y
FuryriderX's Avatar
you need to replace the batteries/clean the board or just get a new one. new they go for ~200. Fil at Eurostyle may have a good cluster for you for a lot cheaper. just swap in your old speedometer so you keep your mileage, and your good to go.
Old 07-23-2007, 08:09 AM   #5
SamE30e
SamE30e's Avatar
Yea, I wanted to avoid buying a new SI board because they are so expensive, is there a way to fix the old one, or find out if a one at the junk yard is working without actually turning the car on?
Old 07-23-2007, 08:31 AM   #6
SamE30e
SamE30e's Avatar
Judging by the wiring diagrams I was just looking at it looks like the Tach is run off the SI board and the temp gauge isn't, actually looking at it now, it doesn't even look like the tach is run off the SI board.
Another thing that doesn't work is the MPG gauge.
Dammit.
Old 07-23-2007, 10:57 AM   #7
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
SamE30...
I have 2 old clusters kicking around... you are welcome to the two of them for $50.00... I used to have an 85 325 e and it's same as yours...
mike
punnzzells is offline   Reply With Quote
Old 07-23-2007, 11:18 AM   #8
SamE30e
SamE30e's Avatar
Thanks, if I can't figure this out i'll have to take you up on that offer. But i'll probably only need one
Old 07-23-2007, 12:42 PM   #9
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Sam, Punzzells (Mike) is the reason my e30 looks/performs the way it was he is a good dude and will hook you up.
My SSK, Chip, suspension and exhaust all came from him.
Also I have a bunch of random ass parts in my basment if you need any.
Stanceiseverything.com
Old 07-23-2007, 12:54 PM   #10
SamE30e
SamE30e's Avatar
What chip do you have?
I was looking at the Turner Motorsports or the Bovarian Motorsport. I'm going to probably gut the cat when I change the clutch then throw a baffled muffler on it. If I do anymore to the motor then that it will most likely be a turbo.
If I can't figure the tach out, i'll probably just get the cluster off Punzzells
Old 07-23-2007, 02:02 PM   #11
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I have a Jim C chip.
Get a Mark D chip though.
Old 07-23-2007, 02:05 PM   #12
SamE30e
SamE30e's Avatar
What are the power gains from it, do you need to run premium?
Old 07-23-2007, 04:31 PM   #13
punnzzells
punnzzells's Avatar
for a 325 E, you get really good HP and torque gains and you extend the RPM's to 5300 instead of 4900.... I think all the chips for this car are pretty much the same.. Turner, Bavarian, Jim C, or Mark D... average of 21-24 bhp and 13 - 17 ft lbs of torque..
if you are going to go turbo, don't buy thr chip.. get a turbo chip or use the stock on as you will want to retard the timing a bit to stay in boost longer... make sure you get a nice KN for the car and cut some small holes in your air box... nice lil mod to do.
mike
Old 07-23-2007, 04:32 PM   #14
punnzzells
punnzzells's Avatar
EEEEEEEE POWER!
you are making me miss my E ... stop it now!
Old 07-23-2007, 04:34 PM   #15
punnzzells
punnzzells's Avatar
many thanks bro!
