Old 07-20-2007, 12:30 AM   #1
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
Question Clunking over bumps in engine bay?
Hey,
Over some harder bumps, if I'm listening carefully without any music you can hear something clunking or shaking after the bump in the front or underneath the car...
Don't know if this is connected, but when the car is idling in neutral I hear kind a sound which some have said could be a loose belt?? Something kind of clunking like a truck-like noise. Strange enough if I push the clutch in, it goes away! And after I release the clutch pedal the sound stays away for a while.
Any suggestions?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 07-20-2007, 02:02 AM   #2
tig
tig's Avatar
you should have a cover on your cat under the car it might be loose, i know i had that problem got the car up on the hoist saw that the cover on my cat converter was loose, especially if your car is lowered which was the case on mine it rubbed up against bumps n stuff on the road and eventually got loose.
tig is offline   Reply With Quote
Old 07-20-2007, 09:09 AM   #3
carjoe
carjoe's Avatar
That second sound could be a throw out bearing for the clutch. When you release the pedal, the sound goes away? Classic symptom. Depending on the car, it can go away when the vehicle has warmed up.
93 325is - sold!
2000 540ia- sold!
Old 07-20-2007, 09:10 AM   #4
Dr. Flyview
Formerly Flav_cool
No...strangely the sound goes away when I press the pedal.
sold
Old 07-20-2007, 09:22 AM   #5
Lower_Level
No-Budget Enthusiast
Lower_Level's Avatar
My car occasionally makes the same sound. Asked my mechanic about it & what he told me was it's the gears in the tranny. When they're not under load they will rattle a little bit. It's common on cars with higher mileage. Not much you can do about it.
'95 325is - //M Body - Shark Injected - Sport Pkg - Depo's with HID's
Lower_Level is offline   Reply With Quote
Old 07-20-2007, 09:35 AM   #6
Dr. Flyview
Formerly Flav_cool
Hmm interesting...
Remember though I have two problems and not sure if they're one and the same.
sold
Old 07-20-2007, 07:32 PM   #7
Lower_Level
well as mentioned, the clunking while you're driving could be the heat sheild on the cat (mine's loose too); could also me one of the brake dust shields loose or broken; or could also be the front strut mounts.
But if you're not moving & getting a rattling/clunking noise while you're engaging or disengaging the clutch; then that sound would likely be a clutch/transmission issue.
Old 07-20-2007, 08:42 PM   #8
Dr. Flyview
Formerly Flav_cool
Hehe, I don't have a cat shield lol... it came off a while ago. I dunno it's not very prominent at all and only over pretty big bumps. The other idling noise is a little stranger.
sold
Old 07-31-2007, 01:59 PM   #9
Docherty
Try checking your tranny oil or changing it. Does your car have a dual mass flywheel? I believe if it does it is supposed to act as a dampener. Could be the problem could be wrong though.
Docherty is offline   Reply With Quote
