Welcome to!
Old 07-16-2007, 01:12 AM   #1
Sunroof Leaking
Hi, recently my E30 has taken to leaking from around the mechnical sunroof handle and from behind the diagnostic light board near the rear view mirror. I am wondering if anyone else has had this problem and what they did to remedy it.
Is it more likely to be just the drains being clogged, if so what is the best way to get rid of the block? Or is it more likely to be the sunroof seal? And if so where is the best place to get a new one from, i live in Perth, Australia but if there is somewhere cheap on the internet it would be great
Thanks in advance
puma325 is offline   Reply With Quote
Old 07-16-2007, 07:24 PM   #2
blow the drains with air if u have a air compresser get a new seal and adjust the roof
Old 07-16-2007, 08:18 PM   #3
Nascar318is's Avatar
Don't you E30 guys have to take out your windows to take the headliner out? If the sunroof is designed like the E36, drop the headliner, undo the clamps for all 4 drain hoses and blow out the lines with a compresser like you said^^^ put the hoses back and the clamps.. open the roof and pour some water in there on the sides and see if the problem is solved. If it is put the headliner back on and you are done.
