Old 07-14-2007, 05:15 PM   #1
E36White
yellow exclamation mark in dashboard
hi,
i turned my car on today and a yellow exclamation mark popped up in the dashboard...i shifted into drive and the car wont drive as it would normally..even when i press the pedal it feels like the car's been roped to the ground!!
what does that mean? it happened a coupla times before..
any ideas?
E36White is offline   Reply With Quote
Old 07-14-2007, 05:42 PM   #2
Michel
Michel's Avatar
is your handbrake up?!
Old 07-14-2007, 06:08 PM   #3
PedroBMW
Hooked on Boost
PedroBMW's Avatar
lol
http://www.foldingtrailers.ca
Old 07-14-2007, 08:46 PM   #4
E36White
no the handbrake sign is red and it says P....besides i almost never use my handbrake...this one actually felt like the transmission has not shifted properly u know what i mean? i just revved it, turned it off then turned it back on and it worked!
but i still wanna know what the problem is
Old 07-14-2007, 10:37 PM   #5
someguy
Singhy
do you mean the exclamation mark with a triangle around and an arrow going counter-clockwise? Thats the stability control. Maybe it was misfuntioning and causing the throttle to be choked??? I unno please explain more.
someguy is offline   Reply With Quote
Old 07-15-2007, 04:27 AM   #6
E36White
was the stability control available on the 92/93 model? yes i believe its that one...its yellow/amber in color..it went on like 3 times in a week span so far...
Old 07-15-2007, 11:22 AM   #7
Jon@Bimmersport
Jon@Bimmersport's Avatar
This is the transmission light, the ! inside the gear loooking object?
Old 07-15-2007, 12:05 PM   #8
vadim321go
vadim321go's Avatar
Press ASC button to turn it off, if u have that button
Proud owner of a 95 325i
Old 07-15-2007, 01:45 PM   #9
E36White
so how do u deal with that? do u need to scan the obd code or something?
Old 07-15-2007, 04:42 PM   #10
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
i am guessing your tranny is toasted. I got a 95 M3 auto tranny if you're interested.
Joe
notjoe is offline   Reply With Quote
Old 07-15-2007, 05:03 PM   #11
E36White
Joe
uhhhh thats awesome!
Old 07-15-2007, 05:38 PM   #12
notjoe
600rwhp here i come
notjoe's Avatar
I went through it! Had to have my tranny rebuilt which cost me like 3k. I also have a ZF m3 5 speed tranny for sale...Personally i would just do a 5speed swap
Old 07-15-2007, 07:25 PM   #13
PedroBMW
Hooked on Boost
PedroBMW's Avatar
5 speed swap
Old 07-15-2007, 07:39 PM   #14
E36White
i'd love a 5 speed swap but thats gona cost at least $2k am i right?
Old 07-15-2007, 11:51 PM   #15
herbalizer
I believe this is normal. A friend of mine has a 330 with an automatic transmission and sometimes he has this sign light up, the automatic transmission will then only shift to 4th or 5th(1st, 2nd and 3rd are not available). This is a "limp mode". He then turns it off and back on and it is fine. The dealership told him that this can happen once in a while and it is OK. As long as it does not happen to you often, you should be fine.
herbalizer is offline   Reply With Quote
