Old 07-17-2007, 03:49 PM   #16
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
Originally Posted by jeffrie
In the same boat currently, would need at least a week still before I can even think about taking it out on the road again, Take some pics, let's see which one is in the most peices .
oh what happened to yours??
Lee you owe my bro & I a ride when its 'operational'
Old 07-17-2007, 05:25 PM   #17
jeffrie
Addict
jeffrie's Avatar
Throwout bearing blew all it's ball barings out, then used the output shaft as a bearing wrecking it.
So since all apart for that and never liked the e36 tranny's gearing from day one (tried it with 3 different diff ratios 2:93, 3:45, 3:91) decided to go with a E30 tranny instead. Then the list got larger.... Then I wanted a single mass fly wheel, upgraded to a stronger clutch, new slave cylinder and while all is apart decided to due some overdue mainanence like change the guibo, centre support bearing, injector seals and well, now also have to change out the starter to go with my new flywheel, linkage ect...
Hopefully will be back together by the end of this weekend and see what #'s come out on that Dyno.
Old 07-18-2007, 12:36 AM   #18
bmdbley'sBro
decided to go with a E30 tranny instead. Then I wanted a single mass fly wheel,
holy crap man thats alot of stuff
i remember doing some reading/ research on bfc about single mass..way lighter!!
so whats involved with a e30 tranny going in (pita)??
Old 07-18-2007, 07:20 AM   #19
jeffrie
Addict
jeffrie's Avatar
Single mass is only 5 lbs lighter 21lbs as opposed to the 26lbd duel mass, but with the single you have the option to shave it down to 18lbs, I didn't bother. Tranny went in like the stock one slightly easier actualy, only the 4 main bolts lighn up so less haseling to deal with while under tha car finding the new weird angles with an asortment of swivels and extensions, biggest PITA was the starter, had to remove the charger just to get to the wires, thinking linkage may be another PITA but only tried with e36 linkage but afraid to bend the aluminium rod to make it work, next I'll try with e30 linkage before I attempt to bend or should I say snap that alum rod.
Old 07-18-2007, 08:40 AM   #20
Nascar318is
Nascar318is's Avatar
Damn that sucks Jeff.. you working on her tonight?
Old 07-18-2007, 10:19 AM   #21
jeffrie
Addict
jeffrie's Avatar
yep, free free to stop buy if your bored.
Old 07-18-2007, 07:22 PM   #22
bmdbley'sBro
Tranny went in like the stock one slightly easier actualy, .
stock for stock yeah, but they don't make 'light weight' dual mass wheels
but im sure you'll notice it rev'n a smidge quicker being 5lbs lighter
