Old 07-11-2007, 12:59 PM   #1
e36_318
angel eyes
Hi guys,
i just picked up a pair of depos with angel eyes and i just cant seem to get the angel eyes working. the headlights/highbeems all work fine but the angel eyes havent even lit up once. i've checked other posts for how ppl have wired them and i still havent figured it out. any help would be great
e36_318 is offline   Reply With Quote
Old 07-11-2007, 01:06 PM   #2
Nascar318is
Nascar318is's Avatar
Did you wire them to your corners or fogs? Is the positive and negative correct? Are they plugged into the inverters?
Old 07-11-2007, 11:33 PM   #3
e36_318
wired them to the corners...as for the positive and neg i used a shitty diagram that came with them so im not to sure...and wtf are inverters lol sorry man im new to this
Old 07-12-2007, 07:29 AM   #4
UltimateDriv
Bimmerhead
UltimateDriv's Avatar
Send a message via AIM to UltimateDriv Send a message via Yahoo to UltimateDriv
the inverters are the little box with wires sticking out.
you connect the inverter to the power source, and connect the other side of the converter to the angel eyes.
you cant hook up the angel eyes directly to the power source
UltimateDriv is offline   Reply With Quote
Old 07-12-2007, 08:31 AM   #5
Nascar318is
^^^ Exactlly. But make sure you're wires from the inverter to the corners are plugged in right. There's 2 wires and the corners have 3.. If I have time today(I'm at work) I'll go take a peek at mine..
Here you go..
http://www.maxbimmer.com/forums/showthread.php?t=69422
Old 07-12-2007, 11:08 AM   #6
Nascar318is
Here is how mine are wired..
Passengers side wires coming out of the inverter..
Brown is going into Brown(on Corner Light)
Grey is going into Grey/Yellow(on corner light)
Drivers side wires coming out of the inverter..
Brown is going into brown(on the corner light)
Grey is going into Grey/Purple(on the corner light)
Hope this solves your problem
Old 07-12-2007, 01:49 PM   #7
e36_318
thanks for the help man ill try wiring em up like that tonight when i get a chance
Old 07-15-2007, 11:58 PM   #8
Nascar318is
So did everything work out or are you still having problems..?
