Old 06-29-2007, 04:09 PM   #1
E46 323ci - common problems, what to look for?
Going to check out a 323ic.
I am going to get it on a hoist and check it out as best as i can. Maybe take it to bimmersport if i have any doubts.
What do you guys suggest I pay special attention to? esp on a higher mileage one.
What are the common problem areas?
Old 06-29-2007, 04:11 PM   #2
P11
rear subframe... make sure its still intact. Most early e46's have this problem.
P11 is offline   Reply With Quote
Old 06-29-2007, 04:34 PM   #3
Subframe, front end stuff (ball joints and bushings), Vanos issues, electrical gremlins. Overall they're not bad at all, seem to have less weakpoints than late-model E36 6-cylinders.
You're so buying it, and it's so my fault.
Old 06-29-2007, 04:38 PM   #4
azn_oo1
how much are u paying for it..and the kms on it pageages that are included
problems...
-sunroof slider
-check the a/c (see if the compressor is still in good shape) they cost a arm and a leg to repair..to check this bring it to a shop that also deals with A/C
check PSI
-check if keys still work they cost 250 a piece
-check for rust
-subframe
thats all i can think of so good luck
azn_oo1 is offline   Reply With Quote
Old 06-29-2007, 04:49 PM   #5
Thanks for the comments, I'm not buying it im going to *see* it,.
How does checking the psi of the r134a tell you if the compressor is good? That just tells you how much r143a is in the system.
Originally Posted by azn_oo1
problems...
-sunroof slider
check PSI
Old 06-29-2007, 05:19 PM   #6
joeys323ci
if you get it on a hoist check the rear diff mount. mine is gone and you need to take the whole rear end of the car out to change it . good luck
joeys323ci is offline   Reply With Quote
