Old 06-28-2007, 05:09 PM   #1
Mavrick
E34 Unstable Suspension
I have a bit of a suspension issue with the 1990 535i. When going over bumpy or uneven roads, it gives me a "darting" feeling that i have to overcorrect in order to keep the car on the road.
Hard to explain i guess, but it's driving me nuts. Front end is tight, i just replaced the thrust arms. These made the car tighter, but the problem is still there. Shocks are origional with 300k on them, and the rear end sits too low, so I plan on putting another set of stock springs in it with newer shocks and struts, but im not sure this will cure my problem.
I've also replaced the rear subframe bushings and the steering box with a used one.
Any idea's?
1988 325i
1990 535i
1995 525i
Mavrick is offline   Reply With Quote
Old 06-28-2007, 07:24 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
i vote blown shocks
Old 06-28-2007, 09:59 PM   #3
Mavrick
Im not sure.. the car settles pretty quick after being bounced, and there are no clunks.. shocks seem OK?
1988 325i
1990 535i
1995 525i
Old 06-29-2007, 12:37 AM   #4
myndgone
..... kLaSSe~1 .....
myndgone's Avatar
Send a message via MSN to myndgone
Any idea's?
you said it yourself....
myndgone is offline   Reply With Quote
Old 06-29-2007, 11:13 AM   #5
Red_Liner740
tramlining?
maybe u need to do alighment again? tires that are reaching the end of their life will dart and tramline like mad.
- 1994 530iT: M60B40'd + 5spd conversion, 18" Style 32's, Magnaflow catback, Voltglands, angel eyes, Erebuni ACS body kit, 10" sub and amp, Alpine deck, soon to be supercharged!!
- 1984 635CSI: 92 535 M30 5spd, Koni Yellows, Eibachs, Magnaflow cat + catback, short throw shifter, Style 5's, 2x 10" subs, soon to have 3.46LSD. STOLEN! baby's gone.
Red_Liner740 is offline   Reply With Quote
Old 06-29-2007, 08:37 PM   #6
Mavrick
Yes feels like tramlining. At higher speeds on uneven roads, the car wants to go everywhere and i have to overcorrect all the time.
Plan of attack is shocks/struts and an alignment again.
1988 325i
1990 535i
1995 525i
Old 06-30-2007, 09:01 AM   #7
MANDD
Autobahn East
E34 unstable_Shocks
It sounds like your shocks have packed it in. If you do a "bounce test "on the E32/34 it will always settle quick even with bad shocks.
e30_kid89 is bang on, you will need shocks. There is a good selection of front and rear dampers out there in the market, depending on your budget.
Mark.
Old 06-30-2007, 11:44 AM   #8
Sounds like rear steering to me.. pitman arms! They hold the rear end steady and wear quite regularly. Super easy to change and cheapish. Made a big difference on my car. bmwe34.net lists them as one of the most common things to go wrong.
Old 07-01-2007, 05:01 PM   #9
Mavrick
everlast, when I had the car on the hoist after i origionally bought it, i had an eye on them, they didn't look in the best of shape. I think i'll go after those next. What'd they cost you and where'd you get them?
1988 325i
1990 535i
1995 525i
Old 07-03-2007, 10:20 AM   #10
I got mine locally, but most places are about the same price, $80 per side:
autopartsonline canada
You can also try to get them from ebay.. most ppl moan about ebay stuff as sometimes you're not sure the brand, but 90% its TRW or Meyle. I've seen them for $50 USD for a pair on ebay!
Old 07-04-2007, 03:13 PM   #11
Mavrick
Ya i like ebay stuff... i got my thrust arms for $150cdn to my door, both sides Meyle brand.
Hopefully those rear pitman links will do the trick.
1988 325i
1990 535i
1995 525i
Old 07-08-2007, 09:47 AM   #12
talltorontoguy
Go Topless
talltorontoguy's Avatar
I've had similar issues (a few times).
- rear subframe bushings
- rear shock mounts
You should replace the springs if you're sagging, the shocks if they're 300k, and do the RSM / dogbones (pitman arms) all at once. See how that goes, then do the subframe bushings if it is persistent.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 07-08-2007, 09:36 PM   #13
Mavrick
I put subframe bushings in it.. i will be doing the rear pitman arms, shocks and springs and i guess ill have to look into the rear shock mounnts. Not sure how the shock mounts would be causing my wondering problem though?
1988 325i
1990 535i
1995 525i
Old 07-10-2007, 05:22 PM   #14
Qube
Have you replaced everything except for the springs and struts now? did you get my mail on the post $?
Old 07-10-2007, 08:48 PM   #15
Mavrick
Hey Qube you never got back to me on the price for shipping on top of the cash for the shocks/springs.. as soon as you do i'll get a hold of some cash and we'll do business!
1988 325i
1990 535i
1995 525i
