Old 06-24-2007, 09:43 AM   #1
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
oil pan has a hole in it...
so the other day i was driving along just cruisin and then i feel a big slam and my car lifted like 2 inches.. then i stop at the first parking lot i see and my car is pissing oil out a hole in the center of my oilpain... it looks like somone left a brick on end in the middle of the road.. so thanks to them i now need a new oil pan.. does anyone know if this is a hard job to replace or not?
86coupe30 is offline   Reply With Quote
Old 06-24-2007, 09:45 AM   #2
86coupe30
1990 325is
86coupe30's Avatar
and or does somone have a spare oil pan for sale for a 325es 86 if that makes any difference
Old 06-24-2007, 12:06 PM   #3
FuryriderX
cra.iX.y
FuryriderX's Avatar
you may be able to patch/jb weld the hole.....typically oil pans are held on by a whole bunch of bolts. the part number is 11 13 1 720 754 if your gonna try to source a new one. all the m20 oil pans are the same, with the exception of the iX, of course. if you take off the pan, remember to replace the gasket. its part 11 13 1 730 234.
Old 06-24-2007, 12:30 PM   #4
86coupe30
1990 325is
86coupe30's Avatar
my dad is cutting the broken spot out and is going to high frequency weld a piece of 1/4'' aluminum checkerplate.. but i was just wondering on how hard it is to take off do i have to take the engine cross member out?
Old 06-24-2007, 12:34 PM   #5
e30jones
To take the oil pan out you have to either lift the engine or take the subframe down a bit. Look for writeups for oil pan gaskets, there are a couple out there....
e30jones is offline   Reply With Quote
Old 06-24-2007, 04:47 PM   #6
biotek
biotek's Avatar
Send a message via AIM to biotek
I have a oil pan $100, pm me if you need it
-Jay
-formally 89, 89, 91 325i
-2001 330i
biotek is offline   Reply With Quote
Old 06-24-2007, 10:36 PM   #7
I got one too
Old 06-24-2007, 10:37 PM   #8
86coupe30
1990 325is
86coupe30's Avatar
alright good to know .. ill be talkin to one of youse if it screws up somehow in the welding process
Old 06-24-2007, 11:09 PM   #9
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Mine got smashed up real good. But I didn't have to fix it
Stanceiseverything.com
Old 06-25-2007, 02:02 PM   #10
86coupe30
1990 325is
86coupe30's Avatar
got another one ,,, and now im making a ballin ass aluminum checker skid plate haha
Old 06-25-2007, 02:03 PM   #11
86coupe30
1990 325is
86coupe30's Avatar
so that shit doesnt happen again
Old 07-03-2007, 09:31 PM   #12
328i Cab
you dont' need to drop the subframe, just the steering rack needs to be unbolted and shifted around. Just make sure you get it back in line before bolting it up. I had to take off a P/S line to get it where it needed to go...now it leaks.
It's a pita to do but you also need to unbolt the oil pump while the pan is just lowered...took me probably 2 hours from start to finish on stands.
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
Old 07-03-2007, 11:22 PM   #13
86coupe30
1990 325is
86coupe30's Avatar
yea soounds about right its been done for a week or two now well a day after when i first posted.. i had the luxury of using my dads freinds hoist so it took a little less time
