Old 06-27-2007, 03:24 PM   #16
e30_kid89
The Afro-stig
e30_kid89's Avatar
^^^ im pretty sure its crackedmine had the same crack where ralph indicated.
Old 06-27-2007, 04:47 PM   #17
dgmorr
You could buy my car and not worry about that.
Old 06-28-2007, 09:34 AM   #18
Striker
Turbo Ready
Striker's Avatar
Originally Posted by static
Hey Raph, long time no post
hmm you brought up a very good point: once i was examining my motor mounts while having a bright light underneath the car. To my surprise, at one point i saw the light shining through a small slot (maybe 0.5mm to 1mm wide) in my front subframe. I asked Charlie whats up and he assured me that this is because of construction of it and they are all like that.
So you are saying that can be a crack? (it looked a bit too straight for being a crack, more like a split between the pieces of metal constituting the subframe)
Hi Alex, I have not been posting much, been extremely busy working on my car among other major projects.
There are a few slots on the front subframe at the end of welded seams, so Charlie is right. If you look at my pic showing the front subframe you will see the lower white arrow crossing a factory weld, look at the ends of the weld and you will see two huge open slots.
I did not weld them close at that spot, I think they were meant to facilitate water drainage, however that slot continues on downwards to the ends and there I welded them shut with 3/16 weld beads. One inch of weld can withstand huge lateral tension so no worries there.
They are not critical stress points but since I am doing the big six turbo swap I welded all of the start/finish slots.
They are not prone to fractures as they are but if you are doing any motor swap or have the motor out I would weld them if I were you.
Take care,
Raph.
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 06-30-2007, 11:06 AM   #19
alex a
2nd generation///
i have a subframe with arms for you good shape $150.00 call me alex 64702018862
alex a is offline   Reply With Quote
