Old 06-22-2007, 07:30 AM   #1
Sm-Sma
Sm-Sma's Avatar
Send a message via MSN to Sm-Sma
lowering my car today! help lol
Hey guys I picked up some h&r springs last night and was planning to do the job myself ! For those who have done this is there something I should know ; any special tools needed? I've lowered many cars but this is my first BMW so I'm a bit scared lol 2001 330i thanks in advance gentlemen!
Sm-Sma is offline   Reply With Quote
Old 06-22-2007, 02:56 PM   #2
zimzimmma
zimzimmma's Avatar
you said you have done this before, but make sure you use the spring remover tool when removing the original springs BEFORE you unscrew the top nut of the strut. The spring is under pressure and will expand if the spring remover tool is not installed on it. depending on which springs they are and how low your going, you shouldnt need them to install the new springs on the struts.
The backs are easy just make sure you e-brake is not on while removing them or else they wont come out lol
did my own and was pretty simple but i have an e36.. pretty much the same.
zimzimmma is offline   Reply With Quote
Old 06-22-2007, 04:11 PM   #3
Sm-Sma
Sm-Sma's Avatar
Thanks man much appreciated ! I do have a set of spring compressors I was just worried because some cars like vw have a tool to take off the top nut. If the proper tools aren't there a job that usually takes an hour can take 5 hours and ten years of your life with all the stress you went through lol
Old 06-23-2007, 04:29 PM   #4
kenzo
I don't know how to install spring, but my mechanic told me it was pain in the "S" when installing the front. In fact, he said 2 persons to install the front will make life much easier.
kenzo is offline   Reply With Quote
Old 06-23-2007, 04:35 PM   #5
Sm-Sma
Sm-Sma's Avatar
Amen to that... so the front is done , last night after work i drove 40 min to my yard where I have all my tools, power and air which makes life so much easier I estimated roughly an hour and half to complete the front. After 3 hours or swearing, sweating, crying I finally finished lol
Guys, i'll write up a DIY tomorrow. NOTE - this job is VERY VERY easy. Why did it take me such a long time you ask? I didn't have my spring compressors so had to use my McGiver skills also after everything was in and ready to be tightened the damn nut holding the STRUT BROKE...
Yes , i cried
Will post DIY tomorrow after rear is complete...
CHEERS!
BTW.... looks AMAZING
Old 06-23-2007, 10:50 PM   #6
Romaz
Romaz's Avatar
Hey I have a 330cic, you wanna do mine to?
Romaz is offline   Reply With Quote
Old 06-24-2007, 01:22 AM   #7
Sm-Sma
Sm-Sma's Avatar
lol, i'll help you if you would like..... but no i'm not that nice
Old 06-24-2007, 12:35 PM   #8
joeys323ci
Sweet cant wait for the DIY , just picked up a set of eibachs . where did you get the spring compressor??
joeys323ci is offline   Reply With Quote
Old 06-24-2007, 12:42 PM   #9
325isRED
325isRED's Avatar
I think you can rent them from autozone
'92 325is 5sp
Old 06-24-2007, 12:57 PM   #10
Sm-Sma
Sm-Sma's Avatar
well... as I said I didn't use the spring compressors, and I do not recommend you do it without them... i'm sure you can rent them at your local auto parts store.
Old 07-07-2007, 04:33 PM   #11
Sneaky
One of the Zealots
Sneaky's Avatar
zimzimmma and Sm-Sma
Give each other back your keys already
THE OFFICIAL BLACK SEDAN THREAD because Nothing breaks necks like a Black BMW.
Sneaky is offline   Reply With Quote
Old 09-14-2007, 01:32 AM   #12
skperformance
where's the DIY?
I have a question , on the rear struts the lower bushing slides onto the carrier pin but what is keeping it held in place. I know there is a bolt but does it have some kind of washer? I have a friend who had his bilsteins installed by a shop in Hamilton and it seem they forgot to install something to keep the shock from sliding off the pin?
thanks
R.I.P. Dad, Shabeer Khan 11/09/06
Toronto area Lexus Owners Meet My 98 LS My 94 ES
skperformance is offline   Reply With Quote
