Old 06-20-2007, 03:28 AM   #1
Luke318is
BMW Fanatic
Luke318is's Avatar
What can cause an odometer to fail?
I have a feeling the cluster is fine, pardon my ignorance, but other than the cluster, what can cause an odometer to stop?
1982 528e -Sold.
1991 318is -Written off, parting out currently.
1984 318i -Beater while car shopping.
1990 ///325i -Imported Mtech2 model, purchased May 28
Luke318is is offline   Reply With Quote
Old 06-20-2007, 04:07 AM   #2
In the 10+ years of working on E30's, i only had one case where the odometer was not working (speedo was fine)...If was caused by a broken gear on the odometer.
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 06-20-2007, 04:30 AM   #3
Luke318is
BMW Fanatic
Luke318is's Avatar
I have a feeling it was disabled, for japanese emmision laws possibly, the rest of the car is mint...
1982 528e -Sold.
Old 06-20-2007, 08:30 AM   #4
dgmorr
Or for exploi...I mean exportation
Old 06-24-2007, 04:24 PM   #5
Luke318is
BMW Fanatic
Luke318is's Avatar
Well theres nothing wrong with the car, if thats what your getting at.
Regardless, any ideas on how to fix it?
1982 528e -Sold.
Old 06-25-2007, 08:17 AM   #6
alex a
2nd generation///
your si board is dead batterys are gone or speed sensor in the diff needs replacing
alex a is offline   Reply With Quote
Old 06-25-2007, 08:19 AM   #7
alex a
2nd generation///
i have a used cluster i can sell you it works battery are new i have 2 of them with rebuilt boards from bmw bring the car to my shop i will fix it for you call me alex 647 201 8862
Old 06-25-2007, 02:31 PM   #8
Luke318is
BMW Fanatic
Luke318is's Avatar
Now your makin me jealous, i dont live in toronto, im in BC
If the battery was gone, wouldent everything else stop working as well? the speedo works fine, so could it still be the speed sensor in the diff?
1982 528e -Sold.
Old 06-25-2007, 04:19 PM   #9
NickP
NickP's Avatar
Are you sure about that? The SI board affects temp / gas / rpms etc but I'm pretty sure that it doesn't affect the speedo.
Old 06-25-2007, 04:55 PM   #10
Luke318is
BMW Fanatic
Luke318is's Avatar
everything works but the odometer and the trip meter.
1982 528e -Sold.
Old 06-25-2007, 06:13 PM   #11
mirek
mirek's Avatar
It's because your rims are not compatible with the odometer. Replace them with something euro.
Old 06-26-2007, 09:29 AM   #12
alex a
2nd generation///
when the batterys are dying different function stop working like on my car the tach temp and gas gauge stopped then would come on intermitantly.
Old 06-27-2007, 04:11 AM   #13
Luke318is
BMW Fanatic
Luke318is's Avatar
Very funny. Like i said, i may plan on changing rims after 5 speed swap. but for now they are fine.
1982 528e -Sold.
Old 06-27-2007, 09:13 AM   #14
rgunner61
almost always, odo problems are from broken gears in speedometer.
it is a common fault and replacement gears are available. try a search
if you want to repair it yourself. speedo works so speed sensor is working.
you could also buy a used one of ebay
good luch
Ron
rgunner61 is offline   Reply With Quote
Old 06-27-2007, 04:21 PM   #15
Luke318is
BMW Fanatic
Luke318is's Avatar
Thanks.
I have a spare cluster with white backgrounds that im swapping in....just need to run back the odometer by about 275k
1982 528e -Sold.
