Old 06-16-2007, 03:30 AM   #1
HPF Chris
HPF 2002 Turbo M3 Goes 11.66 @ 129mph - Video
We took our turbo'd M3 out to the track for the first time tonight. Before hand I did around 20 launches in our parking lot to adjust the KW coilovers, however the 19" wheels and tires were very hard to launch with (especially at this poorly prepped track). I made 6 passes, one of which was an 11.66 @ 129mph. This was as 12psi (610rwhp - 762hp). I turned the boost up a bit more to 13.5psi (640rwhp - 800hp), and the clutch said no more. On the 11.66 pass, I hit 8500rpm in 2nd and 3rd gear and 8400rpm in 4th. I felt like I was shifting at 7,000rpm but it pulls so quickly and so strong through each gear that I didn't realize this until we looked at the datalog. This triggered fuel cut each time which slowed the car down a bit. On the last pull we turned the boost up and I was going to shift early and hope for a lower 11 but the clutch couldn't take any more abuse.
We're going to come back next time with drag radials on 15" wheels and turn the 2.0 60ft into a 1.5 60ft. We hope to plant this car solidly into the 10's as soon as the wheels are made.
Here's a video of the 11.66 @ 129mph pass... HPF750 M3 vs Nitroused C5 Vette
HPF Chris is offline   Reply With Quote
Old 06-16-2007, 05:58 AM   #2
Boots R
Boots, not boost
Boots R's Avatar
Holy ****ing shit. With those HP numbers, you'll pull off low 11's no problem.
Old 06-16-2007, 09:04 AM   #3
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Nice job Chris Glad to see you post here again. Will be representing this kit very soon.
Sickbimmer is offline   Reply With Quote
Old 06-16-2007, 10:06 AM   #4
windsor318is
Nitrous Junkie!
windsor318is's Avatar
i think the price is justified after seeing that video and seeing actual numbers, fab i think i understand why your selling the e36 now lol!!
Old 06-16-2007, 01:54 PM   #5
cisco911
nice ride!!!! Ummm..I hope you didn't buy 15 inch rims for it already cuz the minimum size for your M is 17 inch!
Old 06-17-2007, 12:51 AM   #6
HPF Chris
17" may be true for stock rear brakes, but not it we swap them out.
superM3... Thanks. As always I appreciate the support.
windsor318is... Thanks.
Boots R... Abolutely. A good launch will get us into the 10s with the 129mph trap speed.
Chris.
HPF Stage 5 M3
