Old 06-12-2007, 05:29 PM   #1
S54
S54's Avatar
Please Help Me In Chosing Suspension
Hi in market for MZ3 suspension, any recommendations for my coupe will be greatly appericiated thx.
S54 is offline   Reply With Quote
Old 06-12-2007, 07:04 PM   #2
JazzM
TC Kline would be my suggestion. I'm running the Single Adjustable true match kit from TC kline with 550 F and 700 R spring rates. Previously had 450 all around and looking to go to 600 F.
You're more then welcome to drop by any time and we'll go for a spin.
I also have e30 M3 front control arms and offset bushings, TC/K front camber/caster plates and rear eccentric offset bushings for toe/camber adjustment. I have a 28mm H&R front sway bar and removed the rear one. Using Ireland Engineering rear subframe bushings (You have to get those) and the Randy Forbes rear re-enforcement kit with an e36 dual diff cover.
T.
T.
Old 06-12-2007, 07:08 PM   #3
JazzM
There's a member selling his M Coupe (crusher) with the same kit as well. Perhaps you can trade with him to go back to stock and buy his kit?
T.
T.
Old 06-12-2007, 08:43 PM   #4
Punko
I just installed a set of Bilstein and H&R sports, love them.
Ride is firm and tight.
I also did the rear sub frame but would only recommend you DIY if you have some time and willing to "dig" into the car.
Good luck.
Punko is offline   Reply With Quote
Old 06-12-2007, 08:56 PM   #5
330Hi
330Hi's Avatar
330Hi is offline   Reply With Quote
Old 06-12-2007, 09:01 PM   #6
S54
S54's Avatar
T.
thx Tom for your expertise
Old 06-12-2007, 09:03 PM   #7
S54
S54's Avatar
Good luck.
Are those adhustable heights if not how much drop do you have ?? thx
Old 06-13-2007, 08:43 PM   #8
Punko
They are not coil overs.
I haven't measured the drop. I believe it is around 1" to 1.5".
Thanks.
