Old 06-11-2007, 10:43 PM   #1
Moe
245 40 17 for the rear with M Contour rims 17 x 7.5
Hey All,
I just bought M Contour replica's on this board & he had tire size 215-40-17's in the front & 235-40-17's in the rear. I was wondering if I could put the 235-40-17's in the front & get 245-40-17's for the rear. Any help would be greatly appreciated. Below is the suspension I have on my car right now & the pic of my ride just to get an idea of the drop. Sorry about the quality of the pics it's from my phone camera. The rims are not staggered but I just want to know if I can fit 245's in the rear.
Bavarian springs approx lower your BMW an average of 30 mm (about 1 1/4'') with Tokico blues.
Moe
Moe is online now   Reply With Quote
Old 06-12-2007, 12:52 AM   #2
Soldo
Soldo's Avatar
245's will fit without problems. I've seen some E36's get away with 255's so you shouldn't run into any problems assuming those rims have OE fit. I believe M3's came stock with 245's!
Sexy car by the way!!
Keven Soldo
Old 06-12-2007, 04:53 AM   #3
Moe
Thanks bro appreciate it, but even with that drop I should be ok right? cause the fronts have enough clearance but the rear i'm kinda worried about. I"ll try to take closer pics since i'm picking up the tires during the day I need to be sure.
Moe
Old 06-12-2007, 05:45 AM   #4
Moe
Old 06-12-2007, 07:23 AM   #5
Soldo
Soldo's Avatar
Ya, unless those replica's have a different fitment (offset) than OEM Contour rims, which i doubt. I don't see you having a problem running 245's. Worst case you could always get the fenders rolled for that extra clearence.
Why not just run 235's all the way around?
Keven Soldo
Old 06-12-2007, 08:09 AM   #6
Moe
Yeah i'm planning on just getting the 235's cause I have a feeling if people sit in the back with the 245's in the rear it will rub for sure. Thanks for your help Soldo, I appreciate it.
Moe
Old 06-12-2007, 08:26 AM   #7
mellobudd
jumblebee
mellobudd's Avatar
Send a message via MSN to mellobudd Send a message via Yahoo to mellobudd
looking good moe!
mellobudd is offline   Reply With Quote
Old 06-12-2007, 11:25 AM   #8
Moe
Originally Posted by mellobudd
looking good moe!
All thanks to you buddy.
Old 06-12-2007, 02:13 PM   #9
Stupid Soldo.
Those rims are non-staggered M Contours, meaning 7.5" wide. BMW mounted those with 235/40/17 tires, which is already beyond the max width every tire company recommends for that wheel. Stick with 225/45/17 or if you want to push it 235/40/17.
Old 06-12-2007, 02:44 PM   #10
Moe
Originally Posted by Mystikal
Stupid Soldo.
Yeah bro,
I'm just going to stick with 235's all around.
Old 06-12-2007, 04:37 PM   #11
JazzM
Mystical is right. don't go bigger then 235 on a 7.5 inch rim. I'm running 235 on a 9 inch rim on mine.
Then again, every tire is different and uses its own dimension. Some 245 are as wide as 255 with other manufacturers.
T.
T.
Old 06-12-2007, 09:35 PM   #12
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Car's looking sweet Tom!! Got the balance all sorted out? We need to hip up some beers one of these days (yes, I've been saying that for ages :S).
Old 06-12-2007, 10:41 PM   #13
Moe
Thanks everyone I ended up getting 235's, I want to drop the car lower in the front what's the best set up to go with without any camber wear
Old 06-12-2007, 11:26 PM   #14
Nice, which tires did you go with? The shoulders look fairly aggressive, though it might just be the pic.
Old 06-13-2007, 12:56 AM   #15
Soldo
Soldo's Avatar
You're more interested in tires than you are females........... HOMO!
Keven Soldo
